 Exhaust Gasket
BigRay1125
BigRay1125
Exhaust Gasket Empty
PostSubject: Exhaust Gasket   Exhaust Gasket EmptyWed May 18, 2011 8:23 pm
Is There An Exhaust Donut Between The Manifold & The Exhaust Tubing The Reason Why i Ask Is I Hear Exhaust Leak Under My Hood It Just Sounds Alittle Louder Than It Should
http://www.cardomain.com/ride/2687212/1995-buick-riviera
PostSubject: Re: Exhaust Gasket   Exhaust Gasket EmptyWed May 18, 2011 10:17 pm
Yes there is a flange gasket where the stock down pipe joins the collector.
The 97+ rivs have a slightly different style than the 95/96 rivs but the location is pretty much the same.
What make you think that is where the leak is from? It is much more likely that your manifolds have cracks around the primaries than a leaking stock gasket IMO.
One way to find out is to seafoam the car (brake booster line) and watch where the smoke comes from.
Exhaust Gasket Dsc_0110
BigRay1125
BigRay1125
PostSubject: Re: Exhaust Gasket   Exhaust Gasket EmptyThu May 19, 2011 7:25 am
Not Really Sure Where Its Coming From Just Guessing The SeaFoam How Do I Use It & Where Can I Get It ?
PostSubject: Re: Exhaust Gasket   Exhaust Gasket EmptyThu May 19, 2011 11:03 am
Just type "SEAFOAM" into the search bar(in small caps,otherwise the search bar and a thread explaining how its done.
Exhaust Gasket
» Looking for HMF exhaust
» What kind of exhaust mods are there?
» factory rhino exhaust
» exhaust tip bolt size...
» For Sale Muzzy Duel Exhaust, MSD and Seat Harnesses
