 1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion
4 posters
ejeraser
1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion Empty
PostSubject: 1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion   1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion EmptyThu May 26, 2011 2:33 pm
I have a 1995 buick rivera with 169K on it, I am getting codes P0171 Fuel Trim Lean and P1406 EGR Pintle Postiion Sensor Circuit. Does anyone know what these mean and how I could fix them.
For code P1406 I opend up the EGR and cleaned it out. Would this help? For the P0171 fuel trim lean I am lost as to what needs to be done to fix this. If anyone could help it would be awesome!!
PostSubject: Re: 1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion   1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion EmptyThu May 26, 2011 3:28 pm
Hey Eric, welcome. In the future try the "search" function, theres lots of great info there.
Try this ....
https://rivperformance.editboard.com/t6354-code-p0171-lean-condition-solved-dirty-maf-sensor?highlight=P0171
Merit : 123
PostSubject: Re: 1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion   1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion EmptyThu May 26, 2011 3:55 pm
... and for your EGR code, often they don't respond to cleaning and just need to be replaced.
PostSubject: Re: 1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion   1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion EmptyThu May 26, 2011 5:06 pm
Another note.......if your EGR is stuck (which it more than likely is), a P0171 can be set. Fix the EGR first, clear the codes and see if P0171 comes back.
» CA E85 Throwing Lean Codes in Flex Fuel Vehicles
» Lean (LT TRIM) code
» 1995 Riv NA flashing codes?
» 1995 SC trouble codes and diagnostic
» FAQ: P0171 Lean Condition
Riv Performance ::   Supercharged 3800 Tech :: Series I Scans & Tuning-
