| simple subwoofer solutions | |
| Subject: simple subwoofer solutions Tue May 08, 2007 2:53 pm | |
| I have been having a problem with my woooofer box flying around the trunk everytime I drive anywhere so I have a simple and usually free solution to share. i'm probably going to remake a lower profile version and/or carpet it but this what we got so far and it works beautifully I used the factory luggage nuts for quick and easy removal | |
| Subject: Re: simple subwoofer solutions Tue May 08, 2007 2:59 pm | |
| Good solution. A few VELCRO adhesive strips on the bottom of the box also works well. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: simple subwoofer solutions Tue May 08, 2007 3:04 pm | |
- Good solution. A few VELCRO adhesive strips on the bottom of the box also works well.
hahaha much easier but the problem is i have pieces of wood layin around but no velcro have you used velcro in this car? I tried using it in my late grand am and it didnt stick to the floor at all | |
| Subject: Re: simple subwoofer solutions Tue May 08, 2007 3:23 pm | |
| I use it. You need to get the industrial stuff with bigger hooks. Have to rub it into the carpet to get a good stick. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
SpaceBar Aficionado
| Subject: Re: simple subwoofer solutions Tue May 08, 2007 7:58 pm | |
| I have trouble with my box moving all over the place too. Someday I'm going to have the trunk redone with a much nicer look to it. Have to get the performance done first though. | |
IndyRivi Special
Name : JCrespo Joined : 2009-09-06 Post Count : 8 Merit : 0
| Subject: Re: simple subwoofer solutions Mon Sep 07, 2009 11:08 pm | |
| what kind of setup is that? | |
| Subject: Re: simple subwoofer solutions Mon Sep 07, 2009 11:32 pm | |
| Put in a rear STB and tie the box into that | |
96Super Member
Name : Anthony Location : Huntington Beach, CA Joined : 2009-08-07 Post Count : 57 Merit : 1
| Subject: Re: simple subwoofer solutions Thu Sep 10, 2009 4:29 am | |
- I use it. You need to get the industrial stuff with bigger hooks. Have to rub it into the carpet to get a good stick.
I agree. I used 2 1.5" X 18" strips of velcro and stapled it to the underside of the box. To install and get the box to sit where you want, I put a piece of cardboard under the box, moved it to where I wanted it and removed the box. Now it won't move an inch!! | |
| Subject: Re: simple subwoofer solutions | |
