 Intake Manifold Gasket?
brandonlong
Intake Manifold Gasket? Empty
PostSubject: Intake Manifold Gasket?   Intake Manifold Gasket? EmptyWed Jun 15, 2011 8:19 pm
Hey Guys,
Got a problem, Cars been running hot (210-220), noticed it went in today flushed out the system, put a new thermostat and gasket in, and I noticed there was a pool of water bubbling -- so i cleaned it out and hear enough -- it's back.
I think it's a Manifold gasket? but I am not sure. Small video below and help would be appreciated.
http://brandonlong.me/riv/VID_20110615_201149.3gp
Thanks,
Brandon
darinus
PostSubject: Re: Intake Manifold Gasket?   Intake Manifold Gasket? EmptyWed Jun 15, 2011 10:38 pm
Its hard to see from that video, but are you sure that puddle wasn't caused when you removed the thermostat? Does it refill itself if you dry it? also the bolt for the SC looks wet.
You should check out the elbows that connect at the intake, they crack or leak at the orings, and could pool up looking like a manifold gasket leak.
Northeast
PostSubject: Re: Intake Manifold Gasket?   Intake Manifold Gasket? EmptyThu Jun 16, 2011 12:05 pm
Could be t-stat housing or hose, but 210-220 is normal. Maybe not where you want it, but still normal.
» Can i put some silicone sealant where the carb meets the intake manifold?
» 2" RAIS intake tube for Rhino
» Stock header manifold for 07 660
» 54400111 a-460 trick flow intake new or used
» 170 intake
