BlownRiv Member
Name : Name Joined : 2009-10-10 Post Count : 66 Merit : 4
| Subject: Oil leak? Mon Jun 20, 2011 6:25 pm | |
| When I picked up my Riviera I pulled it onto a tow dolly and have quite the puddle of oil from the car being tilted to that degree. It appears the previous owner was topping it up because I found a funnel and empty oil containers in the trunk. My guess was oil pan or valve cover. I just found it odd to be instantly dripping oil when the front of the car was put on the tow dolly (tilted) any ideas? | |
| Subject: Re: Oil leak? Mon Jun 20, 2011 6:32 pm | |
| could have been pooling in the intake area. Intake gaskets are notorious for failing and oil coming out could be a side effect, as could poor valve cover gaskets. When you tilted it, the puddles ran down the VC. Remember oil spreads out a lot, so not much oil can look like a huge leak. Not likely to be oil pan unless it was VERY overfilled. | |
| Subject: Re: Oil leak? Mon Jun 20, 2011 7:26 pm | |
| Yeah, probably the Intake. I've seen a butt-load of 1/2" deep pockets filled with oil on 3800's. A lil tip like a tow dolly would be enough to make it "spill over". There's really no where else for the oil to pool up, aside from the top of the transmission.... | |
BlownRiv Member
| Subject: Re: Oil leak? Mon Jun 20, 2011 9:42 pm | |
| I didn't know anything was common for leaking oil externally from the intake gaskets. Seems to drip from the transmission pan area and down from there. I will have to get a better look. There is no coolant in the oil or anything like that. | |
| Subject: Re: Oil leak? Tue Jun 21, 2011 6:50 am | |
| I am not positive about that, but other 3800s I've done intake gaskets on have all had oil puddles in there. I wonder if they leak through the intake bolts, I've seen that before. I usually dab RTV on the intake bolt threads when I reassemble. | |
97 park ave Addict
| Subject: Re: Oil leak? Tue Jun 21, 2011 5:38 pm | |
| Just throwing it out there, drain plug is in it right? | |
