 Steering Column Issues
kimble01
Steering Column Issues Empty
PostSubject: Steering Column Issues   Steering Column Issues EmptyThu Jul 21, 2011 9:09 pm
after replacing the Rack and Pinion, no controls operate on the steering wheel, and my Airbag light is on. Where do I check for this?
1998 Riviera
http://www.F1ComptuerServices.biz
PostSubject: Re: Steering Column Issues   Steering Column Issues EmptyThu Jul 21, 2011 9:23 pm
Check connections. check your grounds too
PostSubject: Re: Steering Column Issues   Steering Column Issues EmptyFri Jul 22, 2011 7:53 am
I certainly hope you didn't let the steering wheel turn around too many times! Sounds like you broke the SRS Clockspring...... confused
kimble01
PostSubject: Re: Steering Column Issues   Steering Column Issues EmptyFri Jul 22, 2011 8:11 am
There are few things in life I'm certain about, and this is one: the steering wheel did not move during this procedure! Other than to unlock it to realign the pinch bolt. One thing that did happen when dropping the subframe, the steering was all the way extended as it was the last thing I disconnected.
PostSubject: Re: Steering Column Issues   Steering Column Issues EmptyFri Jul 22, 2011 8:51 am
Well, the only way for all of those symtoms at once is either the Clockspring became disconnected somehow, or it broke.....Although there IS a 2A fuse at the base of the steering column that could've popped.....
» Review: 2009 Suzuki King Quad 500 with Power Steering
» Polaris RZR Steering Column Bearing Kit
» DIY Pistol Mount
» Creaking type noise in steering on Rhino....balljoints maybe?
» Craftsman skipping/slipping steering fix
