pbrktrt Enthusiast
| Subject: IAC valve location? Sat Sep 10, 2011 10:27 am | |
| I need a little info here friends. I don't think my 95 riv sc uses an iac valve or I just can't find it. No issues really, just pm stuff. I've been all over this thing many times in the past, including sc change and fuel rail and injectors. Don't remember seeing an iac. | |
pbrktrt Enthusiast
| Subject: Re: IAC valve location? Sat Sep 10, 2011 10:39 am | |
| Never mind. I found it right above the tps. | |
IBx1 Expert
| Subject: Re: IAC valve location? Sat Sep 10, 2011 11:55 am | |
| Glad you found what you were looking for. It's definitely in a weird spot and has philips head bolts...one of my least favorite things about the Riv while I had it. | |
pbrktrt Enthusiast
| Subject: Re: IAC valve location? Sat Sep 10, 2011 1:17 pm | |
| I agree, the screws are a little cheesy. They look easy enough to remove but I found that it's a little more challenging than it appears. | |
IBx1 Expert
| Subject: Re: IAC valve location? Sat Sep 10, 2011 2:10 pm | |
| If you need to get it out, I took a pair of needlenose vise grips and clamped the bolts down enough to where I could get them out with that, then replaced them with a pair of hex head, allen key bolts. | |
| Subject: Re: IAC valve location? | |
