 If you need to create labels
Merit : 135
If you need to create labels Empty
PostSubject: If you need to create labels   If you need to create labels EmptyTue Sep 13, 2011 8:34 pm
I went into Fry's Electronics looking for transperant peel&stick sheets that I could print from a standard printer and didn't find it but I found something better, for labels.
Casio KL-60. It's a nice simple label maker that uses replaceable lable cassette tapes and it's a sinch to use. Just thought I'd share in case there's anyone else that's looking for a similar solution. This one was cheap too! It was $11 and included a small tape.
If you need to create labels CIMG3534
That's what it looks like.
If you need to create labels CIMG3531
The first thing I used some labels for. Those are all one line but it can also do two-line.
LaFlare
PostSubject: Re: If you need to create labels   If you need to create labels EmptyThu Sep 15, 2011 2:07 am
see this is kind of what i need as the solution to the dash kits that don't have the side panels labeled. but even if its a "clear" tape, it definitively wont look right on a nice woodgrain.
anyone have an idea or solution to properly get those buttons labeled for the side panel dash kits?
LaFlare
PostSubject: Re: If you need to create labels   If you need to create labels EmptyThu Sep 15, 2011 2:17 am
are there any that will just stamp on directly with just the letters? i'm sure there are but i have no idea what they would be called or where to get one... or how much they would cost
» MMA Chat now has a create your own avatar feature
» Tagging Method bait attachment
» How to make the most of your athletic profile
» Boulder Airsoft Patch Design
» (1) Rhino LED Tail light
