 Torque converter causing crankshaft to walk?
designer1962
designer1962
Torque converter causing crankshaft to walk? Empty
PostSubject: Torque converter causing crankshaft to walk?   Torque converter causing crankshaft to walk? EmptyMon Sep 26, 2011 6:03 pm
I just had a rebuilt 3900 series 1 SC engine put in my 1995 Riviera. After around 100 miles the front crankshaft oil seal had moved forward and the engine was losing a great deal of oil. I replaced the seal and the harmonic balancer. After another 95 miles the same thing happened. There has been a vibration in the car since the engine was installed and it has been suggested that the problem could be caused by a bad torque converter. Does this sound realistic? If so, can the torque converter be replaced without pulling the engine and or transmission? I am running out of funds and am hoping not to have to pull the engine out again.
The car is running but losing oil and there is a rapping sound in the engine now. I also see some metal in the oil on the dipstick.
Merit : 153
PostSubject: Re: Torque converter causing crankshaft to walk?   Torque converter causing crankshaft to walk? EmptyMon Sep 26, 2011 11:56 pm
...have to drop the transmission to replace (or even check) the torque converter.
...have you checked the motor and transmission mounts?
96riv
96riv
PostSubject: Re: Torque converter causing crankshaft to walk?   Torque converter causing crankshaft to walk? EmptyTue Sep 27, 2011 1:24 am
I know of some Vigilante converters that have taken out thrust bearings in rear wheel drive 3800's. That engine is toast. Metal in oil means big trouble.
http://www.arizonagn.com
PostSubject: Re: Torque converter causing crankshaft to walk?   Torque converter causing crankshaft to walk? EmptyTue Sep 27, 2011 8:40 am
Metal in oil = Toasted Engine Torque converter causing crankshaft to walk? Help
PostSubject: Re: Torque converter causing crankshaft to walk?   Torque converter causing crankshaft to walk? EmptyTue Sep 27, 2011 9:53 am
I highly doubt it was caused by the torque converter. Not saying it's impossible, but very unlikely. If the TC wasn't installed properly it could be pushing against the flywheel hard, but again, it's unlikely. You would have had major trans problems/lack of pressure if the TC wasn't seated all the way.
Was the engine you old one rebuilt locally, or was it one from one of those 'reman engines installed here' places? If rebuilt locally, you can go have a chat with the machine shop that did the work.
designer1962
designer1962
PostSubject: Re: Torque converter causing crankshaft to walk?   Torque converter causing crankshaft to walk? EmptySat Oct 08, 2011 5:05 am
The engine was rebuilt by an alleged legitimate rebuilder that will cover replacement under their warranty. I am pissed that I have to pay to have the engine pulled and the new one reinstalled. Considering I was sold a defective engine apparently, I would think they should have to bear the labor costs. They don't think so.
The engine of course is a 3800, not a 3900. That was my typo in the original message.
» torque converter setup on mud mower
» Project UTV
» tire swap on TORQUE (ford/craftsman)
» old TORQUE pics
» Me on TORQUE getting some air XD
