 Temp Display now in triple digits?? "1" in front of everything.
Dj Brady
Temp Display now in triple digits??  "1" in front of everything. Empty
PostSubject: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptySun Oct 02, 2011 4:01 pm
About 6 months ago, my battery went stone dead. I resuscitated the battery and all is good EXCEPT ever since then, the temp display now shows a 1 in front of actual readings. If it's 80 degrees outside, it shows 180. If I set the climate control to 74, it shows 174. Did something get zapped when I hooked up the battery charger? (I've never reversed cables, so I know it wasn't that)
Has anyone else ever experienced this issue?
http://www.328studios.com
Merit : 153
PostSubject: Re: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptyMon Oct 03, 2011 12:44 am
I have not had this issue BUT it sounds plausible.
Did you disconnect the battery before charging it (probably not)? Really should.
Might try getting a climate control from a '97 or later Buick Riv or Park Ave at a pick-n-pull? The HVAC heads are available from GM but *mad* expensive.
PS: For future reference here is a link (Vaden Automotive) to PDFs of GM owner manuals for the past ~15 years:
http://www.extendedgmwarranty.com/owners-manual/buick_owner_manuals.html
PostSubject: Re: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptyMon Oct 03, 2011 11:19 am
I have seen somewhere (an older thread here maybe?) this has happened before.
Try disconnecting your battery for 15 minutes - just following the logical conclusion that something went wrong during your power loss, it may clear if you lose power again! (but it may not.)
PostSubject: Re: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptyMon Oct 03, 2011 11:49 am
With the quality of the circuit boards and soldering inside those HVAC heads, I suppose a small short could do it. A small piece of black electrical tape should do the trick until you can fix it. Just an idea if it really bugs you happy
PostSubject: Re: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptyMon Oct 03, 2011 6:52 pm
Any other problems with your car's electronics? I know for a fact a high voltage situation will cause funny things to happen in the display. I also know a weak battery can take it's toll on the alternator. Might perform a quick check of your running system voltage just to rule that out. Should not be above 15.5 volts (13-15v is normal, depending on conditions).
PostSubject: Re: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptyMon Oct 03, 2011 6:53 pm
I'd definitely try resetting via unhooking the battery. If you need one of these units, hunt through ebay. There are a lot of good deals on these things there.
Dj Brady
PostSubject: Re: Temp Display now in triple digits?? "1" in front of everything.   Temp Display now in triple digits??  "1" in front of everything. EmptyMon Oct 03, 2011 8:14 pm
Thanks very much for the thoughts and tips, fellas. I'll try the battery disconnect trick first and see what happens..
there doesn't seem to be any other issues whatsoever.. just an errant 1 in the display.
I will say, it FELT like 170 degrees this summer.. maybe it wasn't so far off. razz
» ARM WARS "TRIPLE ExXxCEL" Excel Exhibition Centre LONDON 28th - 31st May 2010
» Toronto Triple Threat Tryouts (Junior)
» The triple threat workout.
» Water Temp Gauge
» Toronto Triple Threat U19 Junior Tryouts Sep 27, Oct 11 + 18
