| | '96 P0171, hard shifts | |
| | Author | Message |
Northeast Member
Name : Joined : 2010-09-14 Post Count : 84 Merit : 1
| Subject: '96 P0171, hard shifts Thu Oct 27, 2011 6:51 pm | |
| 96 throwing a p0171 code. No misfires currently. New MAF (getting the SES before it was replaced). When the car first starts, it shifts harder than normal, almost seems like it has more low end torque than before the SES-the throttle is very touchy. Doesn't seem like a vacume leak, at least I cannot find one. All the lines were replaced last summer with silicone. There were no new changes or anything done resently that might trigger this code. Was driving one day and the car stalled....drove a few miles and got p0171, p0172, p0300. Cleared the codes, now just get p0171 after 20 mins of driving consistently. Any ides that might help me? | |
| | | Mr.Riviera Expert
| Subject: Re: '96 P0171, hard shifts Thu Oct 27, 2011 6:56 pm | |
| sounds like you may have a break in the wire for the MAF sensor. It seems to be a pretty common wire to break right at the firewall.
When you unplug the maf and run the car does the car behave differently? do you have access to a scan tool to read the MAF hz? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | Northeast Member
| Subject: Re: '96 P0171, hard shifts Thu Oct 27, 2011 7:15 pm | |
| I have an aeroforce, not sure if this is the measurement you meant.
MAF FREQUENCY-reads 2500 - 2800 at idle.
| | | Northeast Member
| Subject: Re: '96 P0171, hard shifts Fri Oct 28, 2011 3:06 pm | |
| just pulled p0171 AND p0172 (rich and lean) | |
| | | Mr.Riviera Expert
| Subject: Re: '96 P0171, hard shifts Fri Oct 28, 2011 10:21 pm | |
| sounds like the computer isnt reading the MAF right. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | Northeast Member
| Subject: Re: '96 P0171, hard shifts Sat Oct 29, 2011 12:39 pm | |
| I originally was thinking the MAF, but the readings seem ok, flow lbs, etc (also was behaving the same way before the new MAF, p0171 and p0172) | |
| | | Northeast Member
| Subject: Re: '96 P0171, hard shifts Mon Nov 28, 2011 8:41 pm | |
| So I solved the issue. It was the 5 month old ZZP fuel rail. I was pulling p0171 and p0172 codes. Went back to the OEM rail and it runs fine now. | |
| | | AA Administrator
| Subject: Re: '96 P0171, hard shifts Mon Nov 28, 2011 8:52 pm | |
| Which type of rail is it, and does anything appear wrong with the rail? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Sponsored content
| Subject: Re: '96 P0171, hard shifts | |
Similar topics | |
