 FAQ: Power Door Lock Problems
PostSubject: Re: FAQ: Power Door Lock Problems   Fri May 08, 2009 11:17 pm
You should be able to remove the small panel behind the door latch, and you might be able to work the rods from there. Won't unlock? hmmm. Is the lock button inside stuck, or disconnected. If it's stuck, try having somebody push the door closed hard while you jiggle the thing...
not much help there I know, but it's worth a shot. Could be the seatbelt latch stuck in the shut door or something...
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Sat May 09, 2009 10:56 am
Good call, deekster.
I took my hip and began pushing in and out and hit the unlock button and voila, it unlocked and opened. I'm not experienced with trying to diagnose these type of problems lol
I guess I'll remove the panel and look for any binding and grease it up.
PostSubject: Re: FAQ: Power Door Lock Problems   Sat May 09, 2009 11:07 am
Also look for a worn hinge. Could be the door sagging low causing some issues.
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Sat May 09, 2009 11:37 am
I'm thinking it has something to do with the latch after playing with it. If it won't unlock I can give the door a shove and then it will unlock. I wonder if it's not latching correctly.
Merit : 134
PostSubject: Re: FAQ: Power Door Lock Problems   Sun May 10, 2009 12:12 am
check the striker.
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Mon May 25, 2009 10:47 pm
albertj wrote:
check the striker.
As in the piece inside of the door held in place by the torx? I'm pretty sure thats what it is. Lube doesn't seem to be doing it, but when it happens I can just shove the door and then it works. May have to get a new one and replace it.
PostSubject: Re: FAQ: Power Door Lock Problems   Tue May 26, 2009 6:49 am
Sure it's not something like the seat belt hanging down preventing the door from closing all the way? I've had that happen many times.
PostSubject: Re: FAQ: Power Door Lock Problems   Tue May 26, 2009 9:27 am
The striker is bolted to the door jam and is adjustable.
mr riviera
PostSubject: Cant open passanger door :(   Fri Jul 03, 2009 3:04 pm
Door wont unlock all the way , outside handle wont engage, inside handle wont work either.
any suggestions, guess i gotta take the panel off and fix it ?
looks like fun with the door shut ???
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 3:29 pm
You can't get the interior panel off without opening the door, unless you want to tear something up. headbutt
You might try using a "Slim-Jim" tool to unlock it directly at the mechanism? scratch
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 3:50 pm
That's what i was going to suggest also.
mr riviera
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 3:54 pm
yeah i used to have one i made outta band strap for a 77 cutlass ... ill give it a try ... any idea wich way it pulls , used to be slide tward rear and pull up when ya had it hooked
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 3:59 pm
Be VERY careful, where the linkage attaches to the mechanism is PLASTIC and breaks very easy!
mr riviera
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 4:02 pm
thats probably whats broken , ill take the panel off the other door first to get a look at what i gotta play with in there ....
mr riviera
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 8:10 pm
well i got the door open , with my makeshit slim jim , gotta replace outter handle , thr rod that actuates the closure is broke i guess ... havent looked yet .... no biggie , atleast i can still use the door
PostSubject: Re: FAQ: Power Door Lock Problems   Fri Jul 03, 2009 8:15 pm
Look here for a "better?" idea than replacing it:
Write-Up: Fixing Outside Door Handle
mr riviera
PostSubject: Re: FAQ: Power Door Lock Problems   Sat Jul 04, 2009 11:54 am
yeah , i could do that ... thanks ... when i get to it . im just glad it opens now .
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 1:57 pm
Well my door handle is now completely inoperable. Have to open it from the inside frown
I saw the writeup but I think I'll just order a new one, I guess.. pending what I see when I pull the door panel
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 2:29 pm
You probably already saw the write up on removing door panel also but just in case:
http://rivperformance.editboard.com/interior-f20/write-up-interior-door-panel-removal-t317.htm#2570
When the handle on my wife's 99 Riv broke it was cold/wet and I knew it would behoove me to carry it and get it fixed instead of making her drive it like that until I could get around to it.
So I had a local body shop repair it, they ordered the part and got it for the same price that I found it for on GM parts direct and installed it for $50.00 labor.
Good Luck
Bert tavis
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 3:13 pm
Yeah I guess I'm gonna order a new one but I don't see anything broken right off hand. I've got it pulled out of the door but still have the rods attached
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 3:43 pm
So I don't really see anything broken. It seems like that spring should move when I pull the handle, but it doesn't. Is that how it works? I don't see how it would move because the rod that goes through it is much smaller than the spring hole.
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 4:31 pm
I've circled in red where the piece is broken ... there should be a hook there that pushes against that metal piece
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 4:39 pm
Yep I pulled the passenger panel to see that. Thanks
Just ordered one from rockauto.
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 5:57 pm
Look in the very bottom of the door and you will probably find the piece that is missing. Also if you get that broken piece out of the door now it wont annoy you after the repair is completed when you are driving down the road and hear it bouncing around inside the door.
Bert tavis
manofmany
PostSubject: Re: FAQ: Power Door Lock Problems   Tue Jul 14, 2009 6:30 pm
Looks like the passenger door handle has already been replaced.
Yep I found the piece. Plastic FTL
