 1966 Riviera GS question.
desertdog71
1966 Riviera GS question.  Empty
PostSubject: 1966 Riviera GS question.    1966 Riviera GS question.  EmptyWed Nov 09, 2011 5:16 pm
Looking at a 66 Riviera GS for sale right now. MZ engine code but missing the dual quad, has a single on it now with the Star Wars air cleaner on it. How hard would it be to find the proper carb setup and get it back to original?
71stagegs
71stagegs
PostSubject: Re: 1966 Riviera GS question.    1966 Riviera GS question.  EmptyFri Nov 11, 2011 12:21 am
Go to v8buick.com plenty of riv experts there
DocModisett
PostSubject: Re: 1966 Riviera GS question.    1966 Riviera GS question.  EmptyFri Jan 27, 2012 8:50 am
Steve,,,,
You can do this fairly easy ,,,,, but,,,, be prepared to spend a bunch of money..... all of the items for the factory correct set up have a hefty price ,,, no matter what it is.....
You will need to get the intake,,, the factory correct carb numbers,,,, the factory correct air cleaner assembly.... [I have seen the correct nut that holds the lid on go for as much as $65] the carb linkage for a factory correct is different from the aftermarket ones.... the correct kick down switch and the bracket that goes with it,,, the right fuel lines,,, and the right power brake fitting and hard line..... the going price for such a set up is usually $1500 or more.... and,,,,, some guy can come along with a good single carb set up and out run it..... assuming the same amount of power for each engine....
Then there is the other side of the coin,,,, you have 2 carbs to rebuild,,, linkage to adjust,,,, ect....but,,,,, the ''wow'' factor is high.......also ,,, in order to get the full potential from the dual carb set up,, you will need the ''other stuff '' to go with it.... [the factory did not just set 2x4's on a engine and let it go down the assembly line] you need a good hot cam,,,, the performance distributer curve,,, and the low restriction exhaust system.....the 3.42 diff with posi,,,, all this must be there or the 2x4's will not perform as it should,,,,
back when I was looking for a riv to buy, I drove a riv, that had the 2x4's on it,,, I could tell when I started the car up and did a walk around listening to it , that it did not have a hot cam and did not have low restriction exhaust,,, and I aint talking about the loud aftermarket types like flowmasters ect....,,,, On the test drive , I let it get warmed up good , then stepped down on the accellerator and the car was a stone..... either one of the cars that I have now would run circles around it..... then the guy was miffed because I offered him less than what he wanted....just some ideas,,,, Doc
PostSubject: Re: 1966 Riviera GS question.    1966 Riviera GS question.  EmptyFri Jan 27, 2012 10:49 am
Thanks for your insight, Doc. Much appreciated!
skatterbrane
skatterbrane
PostSubject: Re: 1966 Riviera GS question.    1966 Riviera GS question.  EmptyMon Feb 20, 2017 6:15 pm
I think the dual 4s was a dealer installed option in 1966. 64-65 was factory installed (but could be dealer installed too of course). But the Quadrajet spread bore manifold and carb were unique to the 1966 Riviera GS making the nailhead quadrajet manifold pretty rare too. The regular 66 Riviera had the typical AFB square bore manifold.
The GTO with the quadrajet actually outperformed the 3-2bbl setup.
» Pulley Question
» grip strength advice..ask david horne any question on grip training....
» Level Adjust Question
» Boston Qualifying Question
Riviera Performance ::   N/A V8 Tech :: 425 V8 Engine & Transmission-
