DEMonte1997 Aficionado
| Subject: Rattling by shifter in console... Mon Nov 07, 2011 10:49 pm | |
| Seems to come from those plastic plates that are staggered and slide around by the shifter. Does anyone else have an issue with rattling sounds coming from their's? Any solutions? I just started doing this a week ago. I'm pretty baffled. | |
BMD Aficionado
| Subject: Re: Rattling by shifter in console... Tue Nov 08, 2011 1:28 pm | |
| I think its the spring mechanism that heeps the cup holder lid up. There some play in there, especially in the open position. | |
| Subject: Re: Rattling by shifter in console... Tue Nov 08, 2011 3:14 pm | |
| - DEMonte1997 wrote:
- Seems to come from those plastic plates that are staggered and slide around by the shifter. Does anyone else have an issue with rattling sounds coming from their's? Any solutions? I just started doing this a week ago. I'm pretty baffled.
you may be able to get rid of the noise with a little silicone spray lubricant. Albertj | |
| Subject: Re: Rattling by shifter in console... Wed Nov 09, 2011 5:44 pm | |
| Thanks for the tips. Giving the silicone spray on a rag a shot first. I don't want any lubricant to get in the console where the shifter is so I'll use it sparingly. Isn't there a shift lock solenoid down there? Don't want that getting dirty. lol | |
| Subject: Re: Rattling by shifter in console... Wed Nov 09, 2011 7:25 pm | |
- Thanks for the tips. Giving the silicone spray on a rag a shot first. I don't want any lubricant to get in the console where the shifter is so I'll use it sparingly. Isn't there a shift lock solenoid down there? Don't want that getting dirty. lol
actually that's why you lube it with silicone spray. Silicone spray is dielectric and won't hold dirt for beans. I mean, don't drown it but a spritz ought to quiet things -- if you move the plastic plates with your finger you'll find they move about quite a bit while your shifter's at the OD detent. With car parked, unlock shifter & move to drive, then with brakes on/engine off spray some silicone spray on the plastic plates and then move 'em back and forth with your finger to spread the lube around. You should hear a difference while doing so. Hopefully this will work. If not probably Ed Morad has/can get you a console top for short money... | |
| Subject: Re: Rattling by shifter in console... Thu Nov 10, 2011 5:58 pm | |
| Good call. Thanks Albert!! | |
| Subject: Re: Rattling by shifter in console... Thu Nov 10, 2011 10:18 pm | |
- Good call. Thanks Albert!!
you are welcome in my car the annoying stupid rattle is, get this... the buttons for the Homelink garage door opener... | |
| Subject: Re: Rattling by shifter in console... | |
