 FAQ: Engine/Transmission Motor Mounts
Go to page : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Merit : 91
FAQ: Engine/Transmission Motor Mounts Empty
PostSubject: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptySun May 13, 2007 9:57 pm
Note from admin: this thread contains general info regarding the mounts used in various Riviera years, sources to acquire parts, and known issues/solutions. For specific procedures and Write-Ups for installation, fabrication of mounts, visit the following links:
http://rivperformance.editboard.com/t2586-write-up-hockey-puck-casting-front-side-motor-mounts
http://rivperformance.editboard.com/t6797p30-write-up-filled-rear-motor-transmission-mount#113123
________
Spotted in the old RegalGS.org forum -
Cheap motor mounts.
$12 instead of $250.
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptySun May 13, 2007 10:10 pm
where was this 6 moths ago when I spent $300 on a new mount. This should be stickied. Thanks for the info
Merit : 135
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptySun May 13, 2007 11:36 pm
does energy make anything for the riv or any other superior brands? I kind of need to replace the front driver and would like to replace all of them with better ones if available and doesnt cost an arm a leg and a nut
Merit : 135
PostSubject: life saving engine mount?   FAQ: Engine/Transmission Motor Mounts EmptyTue Nov 20, 2007 11:33 pm
http://www.zzperformance.com/grand_prix/whatsnew1.php?id=26
Will this mount fit the riv? The only mount i've really looked at on the riv is the passenger side one which is clearly a different mount.
97rivman
97rivman
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyWed Nov 21, 2007 12:51 pm
NO, that mount is for regals and grand prixs...there is a small cradle that bolts to the lower front of the engine and then sits on a subframe slot that is different than ours. You woud need to get a whole different subframe.
steve1173
Name : stephen rabinowitz
PostSubject: Engine/Transmission Motor Mounts (Series II SC)   FAQ: Engine/Transmission Motor Mounts EmptyWed Jun 11, 2008 1:49 pm
On my 98 I was told I need all three bottom engine/trans mounts as they say the dogbone one is good. My mechanic checked & there are no aftermarket ones around & the dealer parts want $299.61 for the front, $137.30 for the left & $328.89 for the rear. I checked GM parts dirct & they are somewhat cheaper. but don't list part #'s so not sure if it is right.
BillBoost37
Merit : 25
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyWed Jun 11, 2008 5:04 pm
Check with Napa..I've had good luck there and using a AAA card you save 7%
steve1173
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyWed Jun 11, 2008 5:38 pm
Tried Napa online & the result I got was,
There were no matches for your search. I checked with a manufacturer of aftermarker Westar & they only make one mount not hte other 2.
Merit : 152
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyWed Jun 11, 2008 11:00 pm
if you use gmpartsdirect, go ahead and use the catalog to locate the items, put them inthe shopping cart, then use the 'view cart' option. The part numbers show up in the shopping cart before checkout. You can move them to the wish list if you want to print out the list and do price comparisons elsewhere. Maybe RockAuto?
BillBoost37
Merit : 25
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 12, 2008 8:21 am
Please.. don't end your searches with online only. Many times a mount is called something different. On my Bonnie..I call them motor mounts..but they are technically trans mounts and no even listed in the same area.
Call..stop in.. have the people do the work for you.
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 12, 2008 1:21 pm
We could probably all use new mounts with our cars being 10+ years old, but that doesn't mean we all NEED them. I had the passenger side mount off to do belts and pulleys a few weeks ago, and yes it was worn, but certainly functional. I'd question the true need to replace yours. What is the year/model and mileage?
steve1173
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 12, 2008 9:30 pm
98 with 78000 miles. You can feel the engine vibrate. Also put the trans in reverse it kicks.
98RIV7777
98RIV7777
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 12, 2008 9:37 pm
Ya, i wish we could get the trans mount cheaper from somewhere other then the dealer, mine kicks when I shift in or out of reverse too, and I have tried EVERY parts store and NONE of them carry any of our engine or trans mounts other then the dealership, and they want way too much for them$$$$$$
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 12, 2008 11:54 pm
rockauto.com should be 40-50% below dealer list price.
steve1173
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyFri Jun 13, 2008 6:26 am
Checked online with rockauto no go.
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyFri Jun 13, 2008 9:57 am
Ask your dealer for a printed quote, that will give you the part numbers. Plug them into gmpartsdirect. Or do as stated above: gmpartsdirect has a Catalog you can browse thru and make selections without having to know the part numbers at first. The catalog selections can be moved to your cart and part numbers will be available.
Turbocharged400sbc
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyFri Jun 13, 2008 2:18 pm
chrysler K car front engine mounts ~12$ each can be readily adapted for use, leave the voids for a stiffer than stock mounting or fill them in with rubber chunks from your OE mount inserts for even stiffer mounts
front mount required two small pices of 1/4 inch plate to be tacked in for spacers, the rear needed one cut to the chrysler mounts steel shell and then it gets shoved into the rear mount, i also chose to shim it with a 3/16ths plate and one 1/4 inch plate.
the plates/shims are no more than 2x2 inches square.
for 24$ and 4 hours of work you cant go wrong...
http://rivperformance.editboard.com/series-ii-engine-transmission-f4/write-up-rubber-trans-mounts-t2841.htm
http://www.sinisterdragdesign.com
steve1173
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyWed Jun 18, 2008 6:19 pm
It seems I need the motor/trans mounts but there are no aftermarket ones available only from GM & the list is about $950 for all 4 + installation but I checked on the net & can get them for about $650 + the installation. Wonder why there are no aftermarket parts for it. When my mechanic called the dealer for the main one the dealer seemed shocked when he said $328.
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyWed Jun 18, 2008 6:26 pm
check the threads about making your own mounts wink hockey pucks work and so do other mounts off other odd ball cars with a little modification.
FAQ: Engine/Transmission Motor Mounts Dsc_0110
Merit : 152
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 19, 2008 7:34 am
When you replace the mounts, keep the takeoffs and overhaul them using polyurethane. Do a search on this forum to find the instructions.
PostSubject: Removing rear trans mount?   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 19, 2008 1:43 pm
Since my car is down for a while due to Trans issues. I figure now is a good time to remove the rear trans mount and try to repair it. I am thinking of doing what ewolf did to his. Anybody got any pointers and or shortcuts to get this out.
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 19, 2008 2:14 pm
Good luck- it's a bear but pretty straight forward. I had my cradle dropped so it made it a little easier. There is very limited room to move around. If your trans is removed for repair it will be much easier.
BTW- if you go with the poly mounts, I think you will be happy. Mine settled after a couple weeks of driving and I love them. Keep in mind I went hard 80A for performance but I think you will be happy with 60A.
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 19, 2008 4:28 pm
can somebody sticky the whole thread about how you made those mounts? I'm going to be referring back to it soon too.
Thanks!
-Derek
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 19, 2008 5:39 pm
PostSubject: Re: FAQ: Engine/Transmission Motor Mounts   FAQ: Engine/Transmission Motor Mounts EmptyThu Jun 19, 2008 7:55 pm
Well the car is going to sit for a week or to till I get my New TCC and some other items. So I am hoping to do this while the car is stopped. I am thinking about using JBweld to fill in the gaps in the mount. Anybody think this is a bad idea? nervous
Page 1 of 10Go to page : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
» 12hp Powerbuilt engine problem.
» Motor Mounts
» How man cc is an 11hp engine?
» Poss. sale of 09 RZR "S" engine
» Please help me diagnose Engine trouble on a 18.5 hp v twin.
