| Which headers | |
+5Rickw albertj Jack the R LARRY70GS 156slim 9 posters |
156slim Special
Name : Sam Jensen Joined : 2014-04-21 Post Count : 9 Merit : 0
| Subject: Which headers Thu Aug 09, 2018 5:45 am | |
| After looking at the zzp website, I have found in the Q&A that the headers dont work for Riviera. Am I wrong? Which headers do other users use and what modifications are required to make them work.
Is there any way to get headers with an egr? Will I still pass emissions? It's a 96 by the way.
Thanks in advance. | |
156slim Special
| Subject: Re: Which headers Sun Aug 12, 2018 12:03 am | |
| Oh, man! I've never gotten so much great insight. Thanks for all the expert advise. I know exactly what to do now. Looks like I'm going to go with the ford f250 tail light assembly mod here. Seems to be the best bet. | |
| Subject: Re: Which headers Sun Aug 12, 2018 12:59 pm | |
| _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Which headers Sun Aug 12, 2018 8:03 pm | |
| The board isn't what it used to be. Most of the members have moved on. | |
156slim Special
| Subject: Re: Which headers Mon Aug 13, 2018 2:16 am | |
| Not throwing a "hissy fit" just seeing if anyone is listening and being silly/passive aggressive about it. And what do you know? It worked. And I have been researching zzp, slp and this forum. This forum is real easy to get trapped in a rabbit hole of how to change your sc oil and 95 mods. The zzp website has lots of q&a that only confuses me. They seem to act like the headers they sell wont work for g body but will for h body and they insist that rivs are h body but according to my vin they are not. I dont feel like sinking $1000 into a full exhaust upgrade on something that's not going to work. I'm pretty competent and am able to do some modifications to the piping or parts that might get in the way but I can't do anything if the ports dont line up. So I only want a link to some of the headers that people have had success with, preferably in a 3" output. Thanks for the link Larry!
156slim Special
| Subject: Re: Which headers Mon Aug 13, 2018 2:32 am | |
| If I buy these headers with a 3" down pipe and a 3" resonator will I have any issues? I wont be able to afford them for up to a year so I'll wait. Anyone with experience please respond. And thank you in advance.
https://zzperformance.com/3800/zzp-stainless-header-package | |
| Subject: Re: Which headers Mon Aug 13, 2018 1:00 pm | |
| Very few of us ever did headers and most of them have moved on. I'm not sure anyone has done headers on the Series I motor. | |
| Subject: Re: Which headers Mon Aug 13, 2018 2:29 pm | |
| - 156slim wrote:
- If I buy these headers with a 3" down pipe and a 3" resonator will I have any issues? I wont be able to afford them for up to a year so I'll wait. Anyone with experience please respond. And thank you in advance.
https://zzperformance.com/3800/zzp-stainless-header-package I tried downpipe and resonator. Larger downpipe, no real issues. However, the larger resonator will probably "drone" at cruising speed. Annoying part is the Riv's a 6, it turns faster than an 8 (say the Northstar) at a given road speed so the drone's higher pitched. You might not care. For me just about all my driving is highway, I didn't like the drone at all. As for the tuned headers IIRC I have heard you might have crossover pipe issues, don't know firsthand and I imagine a work-around could be fabricated locally. For instance getting a tuned header/crossover kit and cutting/welding in a flex connector the right diam/length appropriately, if it's just shape that's the problem, or fabricating a bracket or 2 to move some engine accessories. I really don't know, and again IIRC there was some reason not to bother with tuned headers on the Riv. | |
| Subject: Re: Which headers Sun Aug 26, 2018 9:26 pm | |
| So sorry, I just sent my Riv to the junkyard with perfectly good Stainless headers and high flow cat. The installation was easy with no mod's required. Bolted right up. Don't know about the availability of SSAC headers anymore. Been away from the Riviera scene for a while. Someone her will be able to clue you in to where to get them. It's too bad I wasn't able to strip my car for all the mod's that were on it before it was towed away. You can find the whole set-up @ Rt.117, Auto Parts, Lancaster, MA Phone number 888-771-1171 or www.RT117autoparts.com. See if he hasn't already stripped the powertrain out of it and sold it. The engine had low miles and the trans had about 30K on it. It was sad to see it go but I couldn't do anything with it and it just bothered me to see it in the driveway, so............ | |
| Subject: Re: Which headers Wed Aug 29, 2018 11:18 am | |
| - Rickw wrote:
- So sorry, I just sent my Riv to the junkyard with perfectly good Stainless headers and high flow cat.
It was sad to see it go but I couldn't do anything with it and it just bothered me to see it in the driveway, so............ I need to pretend I didn't read this. I'll just tell myself it was too far to go get the parts anyway. | |
| Subject: Re: Which headers Fri Aug 31, 2018 5:27 pm | |
| JR, I wish my back would have allowed me to remove everything and somewhat strip the car.
3 months before it got parked I had just bought a new front cradle, all GM bushings and bolts and new lower control arms, etc, etc.
Everything up front was new and correct including the mounts that I injected with 3M window weld as well.
Between parts and labor to have it all done correctly cost me over $1,000.00.
Then 3 months later the rear cradle rotted and the right rear dropped preventing me from driving it.
| Subject: Re: Which headers Fri Aug 31, 2018 8:31 pm | |
| MA is too far for me to travel anyway, shame to see it go. | |
nickwon Member
Name : Nick Joined : 2018-06-25 Post Count : 52 Merit : 0
| Subject: Re: Which headers Thu Dec 27, 2018 2:18 am | |
| Any update, OP? Any success installing headers on your car? | |
| Subject: Re: Which headers Thu Dec 27, 2018 11:25 am | |
| Subject: Re: Which headers Fri Dec 28, 2018 1:07 pm | |
| Not sure if the SLPs can even be found anymore. I got over 12 years out of mine, still going as far as I know! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
R1V 1T UP Enthusiast
Name : Timothy Location : Buffalo Joined : 2009-02-05 Post Count : 104 Merit : 0
| Subject: Re: Which headers Fri Feb 15, 2019 11:12 pm | |
| Hello,
I am also looking into a new exhaust system for my '97 and have been finding poor results on the 3800 based sites. Poor meaning e-mailing 3800 Performance and asking for a "will this fit my Riv" question with no response and everything else not bringing up the Riv in the drop down search bars or just a plain "no" answer. Common engine, not so common car I guess? I don't want to go to the custom shop just yet because I believe there's something out there. For good measure, if anyone knows, is there a system out there that gives a full, throaty sound similar to a Subaru Impreza? For a 4 cylinder they sound pretty good imho. Please don't get me wrong, the silent systems are super nice and I appreciate them. | |
| Subject: Re: Which headers Mon Feb 18, 2019 3:19 am | |
| - R1V 1T UP wrote:
- Hello,
I am also looking into a new exhaust system for my '97 and have been finding poor results on the 3800 based sites. Poor meaning e-mailing 3800 Performance and asking for a "will this fit my Riv" question with no response and everything else not bringing up the Riv in the drop down search bars or just a plain "no" answer. Common engine, not so common car I guess? I don't want to go to the custom shop just yet because I believe there's something out there. For good measure, if anyone knows, is there a system out there that gives a full, throaty sound similar to a Subaru Impreza? For a 4 cylinder they sound pretty good imho. Please don't get me wrong, the silent systems are super nice and I appreciate them. Suggest you Look at leaving the system in place from resonator forward but using flowmasters in place of the OE mufflers. | |
| Subject: Re: Which headers | |
| Which headers | |
