riviera90 Special
Name : riviera90 Joined : 2011-11-03 Post Count : 2 Merit : 0
| Subject: 3800 series 1 nonsupercharged swapped to seriers 1 s/c Mon Nov 21, 2011 7:44 pm | |
| im planning on doing a engine swap with my 1990 buic riviera and it has a 3800 non supercharged engine and i wanted to swap with a 1995 riviera and put that engine and trans in mine. But i wanted to no if the axles with work with my suspension or will i have to take it off the 95 and woould that work as well. And also will the engine and tranny mounts bolt up. i meanits still a seriers 1. Help!! | |
ironclyde Enthusiast
Name : Cody Age : 61 Location : Tucson Joined : 2014-01-19 Post Count : 156 Merit : 1
| Subject: Re: 3800 series 1 nonsupercharged swapped to seriers 1 s/c Wed Feb 05, 2014 1:05 am | |
| You may have to worry about your SC bypass valve function. Do you have the ECU and the wiring harness for the 95? Your 90 may have a 4t40 trans. Your local parts man should be able to tell you if your 90 axles will work with your 95 trans. | |
| Subject: Re: 3800 series 1 nonsupercharged swapped to seriers 1 s/c Wed Feb 05, 2014 1:09 am | |
| May be a little late with that reply, ironclyde. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: 3800 series 1 nonsupercharged swapped to seriers 1 s/c Wed Feb 05, 2014 1:12 am | |
| Thanks Aaron, For some reason it was on the dash. Better late than never... | |
| Subject: Re: 3800 series 1 nonsupercharged swapped to seriers 1 s/c | |
