 In Need of Help - Knocking Sound, Blown Engine?
504rivman
In Need of Help - Knocking Sound, Blown Engine? Empty
PostSubject: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyThu Dec 01, 2011 3:05 pm
I just fired up my riviera after 3 yrs. I'm trying to her back on the road
https://youtu.be/sP7jxKJ9q4Q
504rivman
PostSubject: In Need of Help   In Need of Help - Knocking Sound, Blown Engine? EmptyThu Dec 01, 2011 3:49 pm
[youtube][/youtube]
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyThu Dec 01, 2011 4:55 pm
Sorry to say, but it's blown up,mite just want to get a jy motor?
504rivman
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyThu Dec 01, 2011 5:39 pm
Thanks alot..... much appreciated
95rivy
95rivy
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyThu Dec 01, 2011 7:01 pm
Hey bud try taking off the belt to the supercharger. Then try to start your car. It almost sounds like the sc came apart
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyFri Dec 02, 2011 10:42 am
x2 - take the belt off and see if it's the same. If so pull the spark plugs and see if one is smashed - if so you found your blown piston...
Merit : 122
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyFri Dec 02, 2011 11:05 am
My guess is something spark or fuel related is keeping most of the cylinders from running. If it ran fine before putting away, its probably not a chucked piston, just something from sitting. Could have been a bit seized and bent some push-rods trying to get going again. Just needs a bit of a pull apart to see whats goin on.
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyFri Dec 02, 2011 11:16 am
excellent suggestions karma. There is a lot to investigate before replacing the engine.
504rivman
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyMon Dec 12, 2011 12:11 am
The engine was confirmed by my mechanic to be toast
Merit : 153
PostSubject: Re: In Need of Help - Knocking Sound, Blown Engine?   In Need of Help - Knocking Sound, Blown Engine? EmptyMon Dec 12, 2011 11:30 am
try sourcing a used one thru moradpartscompany.com
» engine knock
» Teryx 4 vs. RZR 800
» knocking & where can i also get a engine rebuild kit for a briggs & stratton 21.5hp vtwin?
» Poss. sale of 09 RZR "S" engine
» Mintor 33cc Petrol engine
