 High Compression L36 bottom + L67 SC (Corey's Engine Build)
Go to page : Previous  1 ... 7 ... 11, 12, 13, 14  Next
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Fri Aug 15, 2008 9:39 pm
its not the same engine, and today i saw the mother of all blowers. but im not saying anything u can guess but im not going to say censor
Supercharged
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Fri Aug 15, 2008 9:44 pm
i know i meant the car itself, how many miles on the car.
if it was double supercharged it wasnt the mother
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Fri Aug 15, 2008 9:47 pm
186K on the car,
and for a 3800 this is the mother
Supercharged
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Fri Aug 15, 2008 9:49 pm
whipplecharged?
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Fri Aug 15, 2008 9:54 pm
better IMO
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 11:29 am
WOT runs
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 11:40 am
It looked like you forgot to let her get up to operating temp. before the torque test... no
Bert tavis
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 12:00 pm
yea
i noticed that too
but i did beat a nismo 350Z, and it will chirp second twisted
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 1:58 pm
Where's the Nismo? I missed that part.
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 2:01 pm
that was last night
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 2:07 pm
Oh, then your car must be super fast. A Nismo Z would walk my car even on a good day. Even a stock Z is a very competent rival, running high 13s in the right hands. Can't wait to see your 1/4 times!
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 3:46 pm
haha...... your full of yourself dude...... your like "that wasn't even WOT" but yes you were lol...... at 3:18 or so you sat "that wasnt even WOT" even though its OBVIOUS you were at WOT
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 6:07 pm
hey travis just shut ur mouth
Supercharged
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 7:32 pm
that was clearly WOT at 3:18
Supercharged
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 7:34 pm
real WOT videos, you said you had to make us happy...youve got unsatified people here
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 7:37 pm
then they can send me a check for gas
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 7:40 pm
I like the part where the dash and gauges are all shak'n and shit and you can totally tell when you're entering earths atmosphere....
..yeah, I know...I have an over active imagination...
PEW PEW!!! PEW!!!!
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 7:46 pm
it only shifted at 6k , its an S1x so its probably shifting around 6500 rpms for WOT.
Did you really say what i think you said corey? lol
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 7:47 pm
i did say it
Supercharged
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 8:30 pm
pm sent
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sat Aug 16, 2008 11:34 pm
only if he has it tuned that way................... and for it to "stay" in 1st gear at 6K you have to be at WOT durr da durr.......
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sun Aug 17, 2008 1:54 pm
Agree. Tachs don't climb higher just because they have a cam. 6K RPM is already really high. Even if it shifted at 6200, I doubt it would make it to 6k unless at WOT.
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sun Aug 17, 2008 1:56 pm
i wasnt quite full throttle, i was like 7/8 throttle, thats not full. unless if i learned wrong is school
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Sun Aug 17, 2008 4:48 pm
You may have already done so but just in case...
If that were my engine I would change the oil/filter after I thought it was broke in
Probably after 500 miles.
It sounds good so far. rock
Did you get the wipers fixed?
Bert tavis
PostSubject: Re: High Compression L36 bottom + L67 SC (Corey's Engine Build)   Mon Aug 18, 2008 12:51 am
7/8 throttle is full throttle, the throttle body plate is open all the way at that point
EDITED FOR KINDNESS.....
Page 12 of 14Go to page : Previous  1 ... 7 ... 11, 12, 13, 14  Next
