 Fuel injector leak... weird
crazyjackcsa
Fuel injector leak... weird Empty
PostSubject: Fuel injector leak... weird   Fuel injector leak... weird EmptyMon Dec 19, 2011 5:46 pm
I'm having a hard time getting one of my injectors to stop leaking. It's always the same one, and it doesn't seem to matter which injector I put in that spot.
It's the one that would be closest to the driver, Pressure builds, and it starts to spray. So I take it out, check the O-Ring (brand new and looks good) and put it back in. it starts to spray. So I take it out, swap a couple around and put a different one back in. It starts to spray again. any ideas? The rail looks good, the injectors look good and so do the o-rings, but that one spot just sprays and sprays and sprays.
PostSubject: Re: Fuel injector leak... weird   Fuel injector leak... weird EmptyMon Dec 19, 2011 5:51 pm
test your wiring. try swapping the injector plug with it's neighbor. (will it reach?)
You should be able to pressurize the rail while it's off the manifold, with all the injectors sticking out.
Is it the injectors where + voltage is supplied all the time and the computer pulses the ground? Or is that the fuel pump.
Anyhow, some prodding with an ohmmeter should reveal more.
Merit : 122
PostSubject: Re: Fuel injector leak... weird   Fuel injector leak... weird EmptyMon Dec 19, 2011 6:58 pm
If these are the injectors that I sent you, is it one of the replacement ones? or is it one of your original ones? And it its one of the replacements, try one of the originals, since I have no idea of the state of them. One(or all of them) could be seized right up.
Only other thing I can think of is the hole in the fuel rail is deformed, or the return line is plugged or something. Is the leak at injector to fuel rail? or injector to LIM?
crazyjackcsa
PostSubject: Re: Fuel injector leak... weird   Fuel injector leak... weird EmptyMon Dec 19, 2011 7:17 pm
It's one of mine, the leak is at the rail. It's only the one, all other 5 are great. and if I switch another into the spot, it's the same thing. Can a rail line get deformed like that?
PostSubject: Re: Fuel injector leak... weird   Fuel injector leak... weird EmptyMon Dec 19, 2011 7:54 pm
Where, exactly, is it leaking from? Is it spraying fuel above the injector? If so, it's probably the cup deformed. I have an old fuel rail you can have if that's the case.
» M109R Injector
» TURBO DIESEL INJECTOR PROBLEM
» Fuel for glow engines
» 2006 450 rhino fuel guage
» New Fuel Seat Beard Seats
