 Hello all....
ybnrml
Name : Steven Shearouse
Hello all.... Empty
PostSubject: Hello all....   Hello all.... EmptyTue Feb 07, 2012 10:26 am
I rescently needed a new daily driver (my F250 was eating my lunch @ 70 miles per day comute) and was lucky enough to find a 1997 Riviera. It was garage kept, 56,221 miles from an old retired dentist. So far it has been excellent. I did loose the tension pulley (bearing siezed) on the accessory belt and had to hbble home and start getting educated. My next issue is suspension... it really bounces a little too much and 'squeeks' at front both sides when going over a spped bump or dip in the road... I am assuming the struts are gone and I have one leaking rear shock. I will post some pictures soon. Looking forward to harvesting the knowledge you have here and adding some as I learn (usually the hard way).
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyTue Feb 07, 2012 11:12 am
Nice find, and welcome! The pulley is a common problem most of us have to deal with eventually. Suspension isn't too bad to fix on these cars. Check the write-ups and FAQ. I bet you'll be able to fix all 4 wheels for less than $500 if you DIY.
gmann3001
gmann3001
Name : Glenn W. Peck
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyTue Feb 07, 2012 7:43 pm
I agree with Aaron, check out RockAuto.com they have a discount code here if you search the topics
oh yeah Welcome !
http://gmann3001@yahoo.com
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyTue Feb 07, 2012 9:36 pm
I saw Delco struts on rockauto for a darn good price. The mount kits were a little pricey but livable.
Welcome! smile
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyTue Feb 07, 2012 9:52 pm
Welcome aboard Steven! Great choice for a replacement commuter vehicle. If its a highway commute you should save a bundle at the pumps. Enjoy the forum. surprised
rk0ehn
rk0ehn
Name : Christian Rolf Köhn
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyTue Feb 07, 2012 11:12 pm
Hello and Welcome! hi
I think that the 'squeeks' that you hear are from the Control Arm bushing being worn out if not already loose; I'm telling you this because I have the same problem with mine and yes if it bounces too much like 2 bounces when going through a bump then your shocks are already out. you might want to take a look underneath the car and watch for those bushings. Also take a look at the tire's thread if they are a lil bit worn out from the outside only, it's definitely your control arm bushing and shocks. What I'll do is get the whole control arm and replace it, both of them, because they already come with new bushings AND a new ball joint happy besides the ball joint is "attached" to the control arm itself so everything for 60 dlls each at RockAuto.com will be fine for me, and you avoid the hassle of taking it to a shop so they can compress the new bushings in if you decide to buy the bushings separately.
You got yourself a very nice car and low miles tongue keep it in good shape and you would want keep it forever wink
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyTue Feb 07, 2012 11:14 pm
Welcome...you're in for a fine ride !!! hi
Merit : 152
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyWed Feb 08, 2012 1:33 am
leaking rear shock = replace them both. Delcos, or Monroe MaxAir MA822's. Summit Racing has KYB air shocks.
front too bouncy? the stock front struts are way too soft, IMHO anything will be an improvement. My favorite for ride is the Gabriel strut (I have run new OEMs, Monroes, now running KYBs). The KYBs are a very good ride but not as firm as I'd like - that said they have a long, long service life.
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyWed Feb 08, 2012 1:37 am
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyWed Feb 08, 2012 9:37 am
what is that?
Hello all.... Empty
PostSubject: Re: Hello all....   Hello all.... EmptyWed Feb 08, 2012 10:47 am
haha! that'sAndrew Dce Clay & Rob Englund( Freddy Kruger) in "Ford Fairlane" lol best movie of all time!ZooZoo petals,fuhgehtabouhtit!
Hello all.... Empty
Hello all....
