| Floor Vents Suddenly stopped working. | |
VJD2 Fanatic
Name : Vinny Location : Connecticut Joined : 2010-02-21 Post Count : 310 Merit : 5
| Subject: Floor Vents Suddenly stopped working. Wed Jan 26, 2011 10:20 am | |
| I just noticed this the other day during my trip to Detroit. All the vents work except there is no air going to my feet or the passengers feet. This sucks because its freezing out and my feet are getting cold driving!
Has anyone had any experience with this? The head unit is working and switching to floor mode but no air.
How does the system work on the Riv? Vacuum actuated, electronic doors, etc? Any tips on how to resolve it or diagnose?
Thanks. | |
99Rivman Aficionado
| Subject: Re: Floor Vents Suddenly stopped working. Wed Jan 26, 2011 11:01 am | |
VJD2 Fanatic
| Subject: Re: Floor Vents Suddenly stopped working. Wed Jan 26, 2011 11:12 am | |
| Dammit, I searched too! Apparently not good enough.
Thank you! | |
97 park ave Addict
| Subject: Re: Floor Vents Suddenly stopped working. Thu Jan 27, 2011 3:09 pm | |
| Most likely going to be the air mix/blend door actuator. On my park avenue it is located above the kick panel on the drivers side right by the steering column. | |
VJD2 Fanatic
| Subject: Floor Vents stopped working. Wed Jan 18, 2012 10:19 pm | |
| And just in the knick of time for winter temperatures!
Everything else works, defrost and center vents, just no floor heat.
Any ideas on the resolution or if this is another common failure for these cars?
My feet are cold!
Thanks. | |
| Subject: Re: Floor Vents Suddenly stopped working. Wed Jan 18, 2012 10:43 pm | |
| - VJD2 wrote:
- And just in the knick of time for winter temperatures!
My feet are cold!
Thanks. Do a search on this site for the "actuators" - your probably failed. Significant labor but relatively simple fix with factory or junkyard parts. Albertj | |
VJD2 Fanatic
| Subject: Re: Floor Vents Suddenly stopped working. Thu Jan 19, 2012 10:32 am | |
| Just tried that. Didn't work.
Only thing that came up was the boost bypass valve thread unless I'm doing something wrong here. | |
| Subject: Re: Floor Vents Suddenly stopped working. Thu Jan 19, 2012 11:31 am | |
| _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
VJD2 Fanatic
| Subject: Re: Floor Vents Suddenly stopped working. Thu Jan 19, 2012 11:47 am | |
| Subject: Re: Floor Vents Suddenly stopped working. Thu Jan 19, 2012 4:23 pm | |
| Yes Larry thank you.
Larry mentioned bookmarking interesting posts.
| Subject: Re: Floor Vents Suddenly stopped working. | |
