 Need advice on cams and heads
2 posters
c0reyl
c0reyl
Need advice on cams and heads Empty
PostSubject: Need advice on cams and heads   Need advice on cams and heads EmptyWed Feb 22, 2012 9:40 pm
EDIT:
okay so how much power can the stock heads support?
and
http://intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IR&Product_Code=CAM-67x&Category_Code=3800_HCV
how much power would stage 1 give me out of the box on a L36 with 240 torque, 200 hp?
also, it says that with supporting induction and exhaust mods in place, you could run a 3.0 pulley on an L67. does that mean it reduces engine knock, or does it reduce overall torque to power ratio, gaining power? I don't get it.
also, would this cam plus a supercharger make my L36 engine less prone to exploding as everyone says? and would I need new injectors and fuel rails if I got this, and a supercharger and new valvesprings?
also, is a 160 tstat a bad idea having an L36 to reduce knock even more if I'm running boost on it?
also if I plan on supercharging should I get the supercharged or NA cam?
Merit : 149
PostSubject: Re: Need advice on cams and heads   Need advice on cams and heads EmptyThu Feb 23, 2012 5:25 pm
With any engine, head flow is everything. Good porting will enhance ANYTHING you do to the engine, now, and in the future. Greg Gessler is among the best head porters in the Northeast. He did the heads on my 70 GS455.
http://www.gesslerheadporting.com/gesslerheadporting/ghp.nsf/822dcaaaa26c6da985256dd80023623d/e8e174c35393295085256e5e000a5cde!OpenDocument
I'm not sure how anyone could predict the amount of power you can make, but good porting will up the amount of HP the heads will support. Forced Induction is a great equalizer, and you do not need a big cam. I would go with a super charger cam if you plan on running the supercharger. The engine tune will be everything. You cannot run the same amount of boost with higher compression. Prevent it from detonating, and give it enough fuel, and it should be fine.
» Cams & Rockers
» Series I (SC) Cams
» Nail Head help
» cylinder heads
» Ported Heads
Riv Performance ::   N/A 3800 Tech :: Series II N/A Engine, Transmission, PCM-
