 1996 Riv Battery Light On
BatMobile
BatMobile
1996 Riv Battery Light On Empty
PostSubject: 1996 Riv Battery Light On   1996 Riv Battery Light On EmptySat Mar 10, 2012 2:17 pm
The battery light has been coming on, then it goes off, then comes on again. Hubby has checked the battery so is leaning toward the alternator and specifically the regulator being the problem. The alternator is only a year old. Any help would be immensely appreciated and thanks!
gmann3001
gmann3001
Name : Glenn W. Peck
PostSubject: Re: 1996 Riv Battery Light On   1996 Riv Battery Light On EmptySat Mar 10, 2012 2:46 pm
I recommend checking the connections first. make sure there all secure, if they are then it does sound like the alternator. I had that happen on my Blazer. it blew a few fusees then fried the battery.
http://gmann3001@yahoo.com
PostSubject: Re: 1996 Riv Battery Light On   1996 Riv Battery Light On EmptySat Mar 10, 2012 2:52 pm
Your husband is on the right track, but check connections as mentioned. I would start by checking voltage with car running at alternator and at battery terminal. Should be above 14v running - car is telling you the voltage is not sufficient to charge the battery.
BatMobile
BatMobile
PostSubject: Re: 1996 Riv Battery Light On   1996 Riv Battery Light On EmptySun Mar 11, 2012 3:06 pm
Thanks for the info! The warranty expired last month for the alternator but when Hubby took it back yesterday they just gave him another rebuilt one, so hopefully all will be well. Thanks again for your help. happy
» Compass not happy
» GP 3000 with Light weight Lithium Battery system
» New Minelab GPX Lightweight Battery
» battery failures
» GP3000 - info on Lucky Lark Battery and Coil
