| Subject: Cell phone interfaces Fri Jan 07, 2011 9:11 pm | |
| 'Asking for advice/suggestions on adding a built in cell phone or permanent cell phone interface to a stock '97 or later Riv.
Thanks
IBx1 Expert
| Subject: Re: Cell phone interfaces Fri Jan 07, 2011 10:31 pm | |
| Do you mean something like a bluetooth system? I know when I was looking for a new head unit for the Riv(before the CD player immaculately started working again), you could buy different modules that plug in and mount anywhere inside the dashboard for HD radio, bluetooth, etc. If you have an aftermarket head unit already, look into modules for it. They run about $100 and you need to find somewhere to wire the mic to.
If you're on the stock radio, then I don't know enough to help other than suggesting a pair of bluetooth speakers. | |
| Subject: Re: Cell phone interfaces Mon Jan 10, 2011 12:09 pm | |
| - IBx1 wrote:
- Do you mean something like a bluetooth system? I know when I was looking for a new head unit for the Riv(before the CD player immaculately started working again), you could buy different modules that plug in and mount anywhere inside the dashboard for HD radio, bluetooth, etc. If you have an aftermarket head unit already, look into modules for it. They run about $100 and you need to find somewhere to wire the mic to.
If you're on the stock radio, then I don't know enough to help other than suggesting a pair of bluetooth speakers. Thanks Ilan. | |
| Subject: Re: Cell phone interfaces Mon Jan 10, 2011 12:38 pm | |
| Yeah. I'm not sure if the factory setup can be modified to incorporate a Bluetooth system. Ilan is correct about the aftermarket setup. My Alpine (for example) required a seperate module ($100) to utilize the Bluetooth/HD radio/XM satellite functions. Once installed, you can simply do a Bluetooth device search while in the car with your phone. It will recognize the radio, and viola! Total handsfree use of your phone through the radio. | |
c0reyl Addict
| Subject: Re: Cell phone interfaces Sun Feb 26, 2012 4:23 pm | |
| Might wanna look into this. it's damn pricey, but I plan on getting one eventually.
http://www.pioneerelectronics.com/PUSA/Car/AppRadio/AppRadio+2+(SPH-DA100) | |
The Roadmaster Enthusiast
Name : Carl Alexander Location : Detroit, Michigan Joined : 2011-12-15 Post Count : 128 Merit : 8
| Subject: Re: Cell phone interfaces Sat Mar 10, 2012 6:51 pm | |
| - albertj wrote:
- 'Asking for advice/suggestions on adding a built in cell phone or permanent cell phone interface to a stock '97 or later Riv.
Thanks
I knew that sooner or later someone would come along with an integration process. Here is one that will fit our cars: Blue Tooth Upgrade for Riviera LinkYES!!! | |
| Subject: Re: Cell phone interfaces | |
