 Project: S1 Oil Pan Set and makeover
Project: S1 Oil Pan Set and makeover Empty
PostSubject: Project: S1 Oil Pan Set and makeover   Project: S1 Oil Pan Set and makeover EmptyMon Mar 12, 2012 10:34 pm
Well I finally bit the bullet and decided to put that OP set that was lying on the floor of the Riv in 2day. rolleyes
Oil drained, filter, and oil pressure sensor removed.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover-1
Oil Pan removed.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover4-1
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover6-1
Gasket material stripped and ready for the parts washer.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover8
Banged out a few dings as best I could it'll do for road use. Washed, masked, and ready for paint.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover13
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover9
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover10
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover11
Pan bolts get a makeover
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover14
Ooh! Shiny...
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover16
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover19
Surfaces prepped for gaskets
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover20
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover21
Permatex Aviation Gasket maker. Applied on to pan, then on sealing edge of the top of the gasket.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover22
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover23
Gasket/Windage tray in place.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover24
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover25
Oil pan bolted in place and torqued to 10lbs./ft (14 Nm). To place the windage tray is easiest done by doing the oil pan pickup tube and gasket last. Hang Pan gasket in place with bolts hand threaded on opposite sides of gasket. Install Oil pickup tube and new gasket through hole in tray. Remove hand trhead pan bolts and gasket will hang from oil pickup. Slide pan in place while aligning gasket and bolt it up.
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover26
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover27
Fresh new blood for the Riv. Amsoil Synthetic 10W30 , and long life filter. (even though I still change oil every 5000km's razz)
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover28
Oil in and project complete!
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover29
Underneath the back of her dress...
Project: S1 Oil Pan Set and makeover OilPanSetandmakeover30
gmann3001
gmann3001
Name : Glenn W. Peck
PostSubject: Re: Project: S1 Oil Pan Set and makeover   Project: S1 Oil Pan Set and makeover EmptyMon Mar 12, 2012 10:58 pm
Very nice! looks good. what do you plan to do next?
http://gmann3001@yahoo.com
Now THATS love! and no mistake!
PostSubject: Re: Project: S1 Oil Pan Set and makeover   Project: S1 Oil Pan Set and makeover EmptyMon Mar 12, 2012 11:25 pm
Found a few missing body clips while I was under the car so I'm going to replace them. Gave the chassis a few shot of grease, and next it 3 stage wash n wax for the spring. Will be back on the road at the end of the month after last winters storage. If I find any other issues along the way I'll address them as well. Over all though everything seemed tight. happy Oh and thanks Robo.
PostSubject: Re: Project: S1 Oil Pan Set and makeover   Project: S1 Oil Pan Set and makeover EmptyTue Mar 13, 2012 1:57 am
Looks great!
» Project Peenemünde!
» Project 45 For Sale
» Cheap go kart project
» Another project to add to the list.
» weekend project
