 Leaking Brake Fluid
cragmor
PostSubject: Leaking Brake Fluid   Tue May 22, 2007 9:31 am
Ok, I am baffled on this. I am loosing brake fluid. There is a stain on my driveway, around where the master cylinder is. Cannot see any evidence of a leak there. Followed the lines down the the pressure mod, and no leaks there. The lines crossing over were fine. Checked the line for the left front. Dry as can be.
It is as if the fluid is just being transported from the car to the ground.
Anyone see this, and have any ideas to offer me?
PostSubject: Re: Leaking Brake Fluid   Tue May 22, 2007 10:39 am
probably a leak inside the master cyl. try pressing the brake peddel to the floor and if it slowly just keeps moving then you've got a leak...or air in the lines (but thats another problem lol )
how much is leaking? also did you recently have the brakes serviced? (maybe the resov overflowed with new pads?)
cragmor
PostSubject: Re: Leaking Brake Fluid   Tue May 22, 2007 12:17 pm
Brakes are working just fine, good pressure on the pedal, and it does not go all they way to the floor. Already tested that part. No service on the brakes recently either. Other than missing fluid, and a stain on the driveway, the brakes appear to be just fine.
PostSubject: Re: Leaking Brake Fluid   Fri May 25, 2007 6:13 pm
Check lines going to rear brakes?
cragmor
PostSubject: Re: Leaking Brake Fluid   Fri May 25, 2007 8:33 pm
There is no leaking in back at all. It is all up front.
1998rivman
PostSubject: Re: Leaking Brake Fluid   Fri May 25, 2007 8:57 pm
You're going to have to park it over a clean spot of pavement and wait for a drop. Get under it and look up directly from the point of the drip. Don,t move the car except for up. The leak may not be in a direct line with the drip. Looking up from underneath you should be able to at least see a wet spot and then trace the leak from there. Since you said that it seems to be in line with the M/C, a small crack in the resevoir may be the problem.
Merit : 62
PostSubject: Brake Fluid Reservoir leaking?   Wed Oct 13, 2010 5:49 pm
Hi all,
I haven't been around much lately, but I've been creeping on people's posts now and again razz . Anyway, I have a brake fluid leak! Yay! I'll get a picture, but it appears to be coming from the rear section where the reservoir meets the master cylinder. All the paint around there is flaking off and the fluid is running down the booster underneath where the two bolt together. Luckily, it's not a bad leak.
My question is, is it possible to replace the reservoir only? I wonder if there's a seal that can be replaced between the reservoir and MC. I'll replace the MC if I have to, but the cheaper the better smile .
Picture in a little bit...
Thanks!
-Andrew Z
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 6:03 pm
Yes i believe you can replace just the reservoir, but if its leaking from where the MC and the booster mate then it's not the reservoir. Sounds to me like the internal seals of the MC are leaking.
Not a difficult or costly repair. i did mine about 6mo ago and it took about 30min to change it out and another 30 to bleed the full system.
Merit : 62
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 6:27 pm
Here's the pictures:
Looks to me like it's coming from that rear connection between the reservoir and MC. Thoughts? Seems like I'll have to replace the MC no matter what, but I'm still curious as to what you all think.
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 6:46 pm
well the reservoir is $42 and the entire MC with a new reservoir is $93. I know cost is always a factor, but if it were me i'd just replace the whole thing and be done with it.
I dont know how its setup, but what happens if you get the new resov, pull the old one and the seal on the MC is torn...
Merit : 177
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 7:08 pm
That's what it looks like is leaking to me!!! Buy the whole Master with the resrvoir.
Merit : 133
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 7:11 pm
Z-type wrote:
Hi all,
Thanks!
-Andrew Z
...if you look on RockAuto.com you'll see that MCs are not *that* expensive, probably the best bet is a 'sleeved' reman like an A-1 Cardone. Reservoirs are available and replaceable, a Delco is $43 from RockAuto, but the whole MC (a Dorman) is $38. For my money I'd grab the 'wholesaler closeout' Kelsey-Hayes MC, they were made by TRW, will be about $50. I bought a couple of the "autospecialty" brake calipers on wholesale closeout, they were eye-poppers: came loaded with good (albeit dusty) pads, and were *plated* so I did not have to paint them. The boxes they came in, however, looked like they'd been in the sun way too long, faded graphics and stuff. Which in consideration of the quality of the parts is a huge 'so what?'
Merit : 62
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 9:02 pm
What do you guys think about the Cardone Select version on Rockauto? $48-ish and it appears to come with the reservoir. Would that be the 'new' equivalent to the A-1 Cardone version? Just making sure I don't buy crap...
Merit : 133
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 9:35 pm
IIRC the new Cardone is an import from guess where, and the rebuilt is a rebuilt from NY. Again, for my money - I would def get that TRW "wholesaler closeout" I mentioned. You might want to look at the Cardone site (I don't have link) then decide.
PostSubject: Re: Leaking Brake Fluid   Wed Oct 13, 2010 11:52 pm
I'll throw another vote of "replace the whole unit". Don't try and do anything less.
And I would take Albert's suggestion on what unit to buy, he is the most knowledgeable when it comes to knowing who built what and where.
Don't know where he gets the info but I trust him and his recommendations.
I am on Cardone's email list for product updates and Service Bulletin's, don't remember how I did it, but it can't be hard if I did it.
The following came from one of their latest emails, but I still would imagine that they can have parts manufactured in China and not be lying when they say the following.
CARDONE Industries Production and warehouse facilities in: USA, Canada, Mexico, UK, Belgium
I still try and buy Cardone for new and re-man locally unless Albert has a better solution.
In this case the TRW, if still available will be a better unit NEW.
Merit : 62
PostSubject: Re: Leaking Brake Fluid   Thu Oct 14, 2010 12:26 am
Thanks for all the opinions guys. I appreciate it. Albert - did your Kelsey-Hayes come with a new reservoir? I can't honestly tell from Rockauto's info. Only reason I ask is because my reservoir may be the root of my leak anyway.
PostSubject: Re: Leaking Brake Fluid   Thu Oct 14, 2010 12:34 am
You can try contacting Rock Auto, if that's who you are going through.
I have had good luck with them in the past answering my Email in a timely fashion. Very Quick.
Don't know if they have a phone number listed, if so, go that route also.
Merit : 133
PostSubject: Re: Leaking Brake Fluid   Thu Oct 14, 2010 12:34 pm
ask rockauto; odds are it does but there is no picture. If not the Kelsey-Hayes then I'd take the *reman* Cardone.
Merit : 62
PostSubject: Re: Leaking Brake Fluid   Thu Oct 14, 2010 9:24 pm
Thanks guys...I'll send them an email and see. I'm not sure how much farther I'm going to trustthis MC. I just wish there was nicer weather! Then I wouldn't mind letting the Riv sit until it's fixed and using my Lesabre T-type! I'll report back.
Merit : 62
PostSubject: Re: Leaking Brake Fluid   Tue Oct 19, 2010 5:23 pm
Well, the leak got pretty bad the last few days so I had to skip out on Rockauto and get one local. Had to get a Cardone Select after all. Hopefully it was an OK decision and it'll last me a long time. Came with the reservoir and whatnot too, so that was a plus.
Anyway, the leak was bad enough that when I'd get to work and park, a small puddle would form. And by small I mean, 'good god what else is broken?' . I'm trying my hardest to get this thing fixed by tomorrow evening. I have a good guy to help me, so it'll get done right at least. Mostly I'm trying to avoid using the T-type in the rain razz .
PostSubject: Re: Leaking Brake Fluid   Tue Oct 19, 2010 7:25 pm
Cool, you will get her done!!! James say's hello also.
PostSubject: Re: Leaking Brake Fluid   Tue Oct 19, 2010 10:35 pm
What's wrong with using the T-Type in the rain.????
Do you just prefer not to or is their some mechanical reason not to run it in the rain.?
Merit : 133
PostSubject: Re: Leaking Brake Fluid   Tue Oct 19, 2010 11:33 pm
Low-pH rainwater --> rust, in industrial Pittsburgh and surrounding area.
Merit : 177
PostSubject: Re: Leaking Brake Fluid   Wed Oct 20, 2010 11:17 am
Don't forget to bench bleed the Master Cylinder before you hook up the brake lines!
Merit : 62
PostSubject: Re: Leaking Brake Fluid   Wed Oct 20, 2010 8:10 pm
Rick - I just want to avoid the acid rain as much as possible, also, I'm lazy:). It has a layer of dust on it right now, so I'll wipe off the whole thing, but if I can avoid rainspots and stuff, I try to. I just put too much hard work into that car inside and out to get it rusty or something of the sort. Therefore, Albert is right razz .
Thanks for the reminder Scott, but the job is done! I trust my mechanic to do it right. He's done some complicated stuff for me in the past so I have faith that he did that. I'll ask him tomorrow anyway since I'll see him.
I checked out the inside of the old MC and I can see why it was leaking. There's a couple O-rings inside there, and they have just about disintegrated. That's about it. Thanks for all the advice as always everyone!
Leaking Brake Fluid
