| Subject: Will 96 sway bar brackets fit on 97? Tue May 22, 2007 6:35 pm | |
| I'm guessing there was no need to retool the bracket area on the frame when the bracket design changed for 97, but I could be wrong. Still trying to figure out how I can use camlifter's nylon bushings | |
| Subject: Re: Will 96 sway bar brackets fit on 97? Fri May 25, 2007 6:17 pm | |
| Talking about fronts? They should work, imo. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Will 96 sway bar brackets fit on 97? Fri May 25, 2007 10:20 pm | |
| Both.
Surely if the fronts work the backs brackets will too. I think they're just held on with one bolt. | |
| Subject: Re: Will 96 sway bar brackets fit on 97? | |
