| airbag light anyone | |
jonnyb411 Member
Name : Jon Age : 37 Location : new jersey Joined : 2010-04-22 Post Count : 54 Merit : 0
| Subject: airbag light anyone Fri Mar 16, 2012 7:19 pm | |
| DTC B1021 Driver Deployment Loop Resistance High
DTC B1061 Lamp Circuit Failure
my airbag light came on and these are the codes i pulled.. anyone now how to fix? | |
| Subject: Re: airbag light anyone Sun Mar 18, 2012 6:46 pm | |
| did you check the airbag fuse and wiring? | |
jonnyb411 Member
| Subject: Re: airbag light anyone Mon Mar 19, 2012 8:21 pm | |
| - albertj wrote:
- did you check the airbag fuse and wiring?
checked fuse not wiring? | |
| Subject: Re: airbag light anyone Mon Mar 19, 2012 10:22 pm | |
| - jonnyb411 wrote:
checked fuse not wiring? ...yes the wiring. Nature of the airbag circuit and device design is it's got to be highly reliable in order to work at all. More than half the airbags in cars made in the US were made by Thiokol, who also made the inflatable cushions that broke the fall of the Mars lander and a number of propulsion systems, solid fuel rocket stuff, et cetera. It's actually a fairly dangerous defice and they don't eff around with the device or its electronics. So yeah, first do a quick visual check of the wiring. Don't plug/unplug anything just get a look... and this is not going to be all that simple. You may find a plug has come loose or some other problem BUT don't plug it back in until you depower the system. Next - Get a factory service manual. It tells you how to depower the airbag system and troubleshoot. Albertj | |
jonnyb411 Member
| Subject: Re: airbag light anyone Tue Mar 20, 2012 5:11 pm | |
this sounds like a pain in the ass lol. thanks though | |
matt270avian Expert
| Subject: Re: airbag light anyone Wed Jan 23, 2013 5:38 pm | |
| Did you have any luck? My airbag light is on but no one around here can scan it. Any details on depowering the system besides removing the battery leads? What wires should I check? Do's and Don'ts, etc... | |
| Subject: Re: airbag light anyone Wed Jan 23, 2013 6:06 pm | |
| First check system voltage while running, should be under 15 volts. A bad regulator can produce high voltage that can trigger the air bag lamp and cause other gremlins to arise. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
matt270avian Expert
| Subject: Re: airbag light anyone Wed Jan 23, 2013 6:10 pm | |
| When I checked volts during the PAC install everything was under 15. | |
jonnyb411 Member
| Subject: Re: airbag light anyone Wed Jan 23, 2013 7:44 pm | |
| - matt270avian wrote:
- Did you have any luck? My airbag light is on but no one around here can scan it. Any details on depowering the system besides removing the battery leads? What wires should I check? Do's and Don'ts, etc...
i just took out the light!!! youtube downloader | |
matt270avian Expert
| Subject: Re: airbag light anyone Wed Jan 23, 2013 8:09 pm | |
| Not my preferred solution, but........ | |
| Subject: Re: airbag light anyone | |
