 95 Rivi
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: 95 Rivi   95 Rivi EmptyThu Apr 05, 2012 10:56 pm
hello everyone happy to get to chat with yall, I have a 1995 Rivi, the problem i've haveing is that my car will start almost every time I turn the key, how ever every 10th or 15th start, it just won't start, it will turn over but won't run, i have to let it sit sometimes for 2 or 3 hours, and it starts fine, for at least 10, or 15 more starts, and then again, does anyone have any idea what could be causing this?? thanks, and again it's a pleasure to see so many Rivi enthusiast. you guys have a good day!!
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyThu Apr 05, 2012 11:21 pm
Fuel pump or FF would be where I would first suspect, possibly (I doubt it) injectors. You getting fuel? Can you hear the pump turn on when you turn the key on before cranking it over? Scan for codes. Check the fuel pressure at fuel rail and make sure fuel is actually getting there. check for spark, Vacuum leaks. If you get all those checked without success get back to me and we can go further into the sensor end of things.
smile
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 12:24 am
Sorry misread your initial post, upon 2nd read I would look at crank shaft or camshaft sensors
gmann3001
gmann3001
Name : Glenn W. Peck
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 12:49 am
Hello! and Welcome! hi
http://gmann3001@yahoo.com
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 1:00 am
welcome Juan
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 9:02 am
hello again, we've checked the Rivi out, fuel pressure is about 1 lb low, fuel filter was changed, the fuel in it was black, no codes, no vacuum leaks, still did it one more time
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 9:05 am
thank you Stan
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 10:20 am
Make sure the key is clean and dry. Does the '95 key have the little chip in the key? You might want to brush it clean with some scotch brite or steel wool. Do you have a lot of stuff hanging on your keychain? If so get it off! You will wear out the ignition switch.
Does the security light flash when it won't start?
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 7:27 pm
just fob and door lock key, will try it steel wool? 10-4, no the security light does not flash
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 06, 2012 7:29 pm
this is my first Rivi, I love it!!!
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyTue Apr 10, 2012 8:51 am
may have found a secret to my car, turn the key wait bout 10 sec, then start it, it seems to be working
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyWed Apr 11, 2012 9:16 am
another wonder, my drivers side window wouldn't work, like a miracle it started workin!! sorry, I get a little excited, I love my car
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyWed Apr 11, 2012 9:37 am
WELCOME ABOARD !!! hi
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyThu Apr 12, 2012 8:18 am
thank you, nice Rivi! smile
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyThu Apr 12, 2012 7:40 pm
hey guys did yall abandon the forum???
black shadow
black shadow
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyThu Apr 12, 2012 7:48 pm
Juan Hometown hero is probably right on the money, it most likely is a crankshaft positioning sensor and there not hard to replace and there not to overly expensive either,
Hometown hero I got to tell you that trunk looks awesome, and the engine compartment is out of this world, it looks great. rock
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyThu Apr 12, 2012 8:28 pm
the thing is that the car runs just fine, it's when its been turned off when the problen ocurs after, like 10 minutes after its. been off
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyThu Apr 12, 2012 9:58 pm
Have you scanned it for codes? I would still lean towards the sensor end of it, have you ruled that out already? Might have something to do with the "security" system on your car? Oh and thanks black shadow. happy
gmann3001
gmann3001
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 13, 2012 1:18 am
Nope. were still here. Just lurking in the shadows twisted
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 13, 2012 4:08 am
I'm having a new key made for it, maybe thats the problem. happy
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 13, 2012 4:12 am
I asked about sensors, they said if it was a sensor, it would probably dir while i was driving, black shadow, you buildin a stovebolt, I'm buildin a 53. offtopic
black shadow
black shadow
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyFri Apr 13, 2012 7:48 pm
yeah mine is a 49 and completely modified and since I have started driving big truck again I haven't had anytime to work on it, it just sits in the garage collecting dust.
juan_sylvia
juan_sylvia
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyTue Apr 17, 2012 8:56 am
I have recently found that when it won't start, i turn the key to "on" and back off, 3 or 4 times, then it does start, any takers??
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyTue Apr 17, 2012 9:21 am
Do you have a check engine light? That's pretty important to note for a problem like this. If you do, it's probably the crank or cam position sensor. Mine did the same thing.
black shadow
black shadow
95 Rivi Empty
PostSubject: Re: 95 Rivi   95 Rivi EmptyWed Apr 18, 2012 7:11 am
WELL I HAVE TO THINK THAT IT IS YOUR SECURITY SYSTEM
95 Rivi Empty
95 Rivi
