rk0ehn Enthusiast
Name : Christian Rolf Köhn Age : 34 Location : CD Juarez, MX Joined : 2011-08-11 Post Count : 148 Merit : 14
| Subject: Power Steering Fluid Tue Apr 10, 2012 2:56 pm | |
| Hello, I just have a question: What type/brand of fluid do I use to fill the power steering? Thank you. | |
| Subject: Re: Power Steering Fluid Tue Apr 10, 2012 3:05 pm | |
| I use Prestone.Works good.I also add a little Lucas P/S fluid to keep things nice & quiet. | |
rk0ehn Enthusiast
| Subject: Re: Power Steering Fluid Tue Apr 10, 2012 3:16 pm | |
| Thank you robo, Is that like a red fluid or transparent fluid? can I use something like Dexron II or III? I'm asking this because I know if you mix different fluids you will weak the seals and cause leaks on the system. This happened to me on a ' 01 cavalier, I use the Autozone Power steering fluid and it was kind transparent when the original fluid is red and later on i had a leak at the rack and pinion when I had none at that time | |
| Subject: Re: Power Steering Fluid Tue Apr 10, 2012 3:30 pm | |
| Ive only ever used Prestone with the Lucas stop leak.I use the Lucas Because its compatible with any P/S fluid and it works to keep seals pliable and squeek free. Prestone is clear wit the Lucas being red.
Seafoam makes a P/Steering flush chemical to flush the system and then refill with the fluid of your choice. I havnt done this yet But I plan too.
I am not sure but using Tranny fluid in place of the P/S fluid dont sound so good...
I also might add that as a rule I dont believe in additives of any kind. But I do like the Lucas stuff. It took away my P/S whine real quick. | |
| Subject: Re: Power Steering Fluid Tue Apr 10, 2012 3:41 pm | |
| Do not use transmission fluid in the power steering. This system wants power steering fluid. I use prestone. It should be drained and refilled occasionally.
Every power steering system is different. In the old days we substituted ATF with no problem. I wouldn't do that today. | |
rk0ehn Enthusiast
| Subject: Re: Power Steering Fluid Tue Apr 10, 2012 3:48 pm | |
| Yup, i know it used to be where you can use just ATF, I think on the Service manual of the cavalier mentioned something like dexron II, so I was not sure what to use with the Riviera. I guess I would use the Preston P/S fluid and try the Lucas stuff | |
| Subject: Re: Power Steering Fluid | |
