 p0703
Pipes
Pipes
p0703 Empty
PostSubject: p0703   p0703 EmptyTue May 22, 2012 11:37 am
where is shift solenoid b at on 95 riv is it inside trans casing or could i do it with out take whole tranny out?
p0703 Empty
PostSubject: Re: p0703   p0703 EmptyTue May 22, 2012 12:14 pm
I do believe its been replaced without having to take it out.I saw the write up somewhere.You still have to remove a ton of stuff.Cv ,wheel tire etc etc....Wish I could find that write up.If you look at the FSM for the 95 you will see that its possible.might need a new gasket though.I know that case gasket is a hard plastic type.
Pipes
Pipes
p0703 Empty
PostSubject: Re: p0703   p0703 EmptyTue May 22, 2012 12:35 pm
ok since i got to take the half of the tranny off are there any mods i could do while i inside the casing
p0703 Empty
PostSubject: Re: p0703   p0703 EmptyTue May 22, 2012 12:46 pm
I really doubt it.I think you have to remove alot more than the case to do AnyThing to the trans if anything is even available for our year.
this is available.http://www.makcotransmissionparts.com/T84167E.html
p0703 Empty
p0703
