 95 Riv SC - trans problems
bullydave
95 Riv SC - trans problems Empty
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyThu Jul 28, 2011 2:01 pm
new to the forum but just got a 95 riviera supercharged transmission starting to slip does any one know what transmissions would be compatible with this
PostSubject: temp   95 Riv SC - trans problems EmptyThu Jul 28, 2011 3:36 pm
Welcome to the forum! The 4T60E is the stock transmission for the 1995 Rivs. I'm not sure on available aftermarket trannies for it, but if you have the $ anything is possible in theory.
sniperdude
sniperdude
Merit : 18
PostSubject: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyMon Jun 04, 2012 5:39 pm
Hey there guys, new here.
I bought a nice fixer upper 95 Riv with the S/C 3800. 128K on her.
The car runs nicely, minor things all over the place but the glaring issue I need to get fixed was that the car only has reverse gear on transmission.
My buddy had a 95 Park Avenue Ultra with the same setup and his trans went out at 50K or so.
I am trying to figure out what the best course of action is. Rebuild? Replace? Money is kind of a factor, but I figure replacing it with another junkyard trans will just net me the same eventual problem.
Thanks!
pbrktrt
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyMon Jun 04, 2012 7:34 pm
The trans is unique to that car only. Save up for a rebuild is probably your best bet.
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyMon Jun 04, 2012 8:24 pm
There is a way to replace the solenoids on the 95. I dont know how but it's been done.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 08, 2012 3:41 pm
Yeah, except if it needed new solenoids, I'd figure there would be an SES light for that.
I'm figuring it probably needs to be rebuilt, as much as that sucks.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyThu Jun 14, 2012 3:23 pm
I'm having it rebuilt next week. Is there anything else that should be done while I'm down there?
I was thinking transmission mount and rear main seal at least.
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyThu Jun 14, 2012 8:17 pm
Yup.take care of that rear mount.if its original replace it.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 15, 2012 11:47 am
Right now I'm looking into an issue to see if a dying battery or thermistor is the cause of the trans not having drive gear. I know if the car is in limp mode you should be able to get 2nd and 3rd gears, in addition to reverse. I didn't test this before.
Putting in the new batt tonight, will see if that fixes things up. I would be freaking ELATED if that was the case.
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 15, 2012 1:28 pm
I hope you bought an Optima.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 15, 2012 3:01 pm
Why is that?
sniperdude
sniperdude
Merit : 18
The optima isn't an OE fit.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptySat Jun 16, 2012 7:45 pm
I picked up that OEM battery, checked the transmission - none of the forward gears work at all. So I guess it's replacement time.
Also I found some odd wiring in the dash fuse panel. Any of you guys know what the hell this might be? Looks like some really bad splicing.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptySat Jun 16, 2012 7:49 pm
95 Riv SC - trans problems Buickwiring
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptySat Jun 16, 2012 7:50 pm
Looks like they're tapped into the Crank and WSW (windshield wiper?)
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptySat Jun 16, 2012 10:19 pm
those look like jumper wires.I would find out what they are wired to do?!
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 29, 2012 1:15 pm
It's been awhile since I posted, but the car is still in the shop getting a bunch of stuff done to it that my mechanic found.
Transmission replaced, engine cradle replaced (rotted out), belt pullies and tensioners, Accessory and Supercharger belts replaced, oil pan gasket replaced, rear main seal replaced, AC leak diagnosed and fixed, AC recharged, oil changed, exhaust repaired, starter replaced.
Lol, so much for a cheap fix.
gmann3001
gmann3001
Name : Glenn W. Peck
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 29, 2012 2:13 pm
I feel that! Got a list of my own I'm workin on... It seems That once you get one thing done
you all ready have six more things planned.
http://gmann3001@yahoo.com
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 29, 2012 2:31 pm
Am wondering... what's a rebuild cost for the '95 SC trans.?
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 29, 2012 6:31 pm
around 2100 on the low side.
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyFri Jun 29, 2012 6:55 pm
Thanks.
FYI, I just posted a used '95SC trans in the for sale section.
http://rivperformance.editboard.com/t9416-for-sale-95-sc-series-i-transmission
Way less than the rebuild number, and low miles.
Thanks for looking.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptySun Jul 01, 2012 11:40 am
Wow, that's some low mileage. Wish I would have known. Haha
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyTue Sep 11, 2012 5:15 pm
After all that I still haven't driven it much since I found out the brakes suck big time, and also the brake lines are rotting out, so gonna have to get that fixed up soon.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: 95 Riv SC - trans problems   95 Riv SC - trans problems EmptyThu Oct 11, 2012 1:59 pm
Ohh man, I hope this isn't going to be bad to look into. I'm probably gonna have to take part of the dash off to look at it.
» Transmission problems
» Trans axle issues again, please help!
» 1st attempt at a MTD vari drive and 3 speed manual trans mutation
» RZR Wheel Hub Problems?
» 3500 still has problems
