| I hope somebody can help me... | |
gmann3001 Fanatic
Name : Glenn W. Peck Age : 50 Location : Orland Park, IL. Joined : 2011-11-16 Post Count : 389 Merit : 9
| Subject: I hope somebody can help me... Wed Jun 06, 2012 8:48 pm | |
| Is there an door wiring harness that can be unplugged in the dash! I was looking over some things in my Riv that need attention and my drivers door lights and most of the switches don't work! I moved the rubber boot and found about 6 broken wires! my problem is that I don't have enough room to work with the rubber boot in the way. I think I saw something about this issue in the past but cant find it in the search. | |
| Subject: Re: I hope somebody can help me... Wed Jun 06, 2012 8:53 pm | |
| I dont know about a disconectable harness from the cabin.Dont mean there aint one.Cant you make the repairs in the space youhave? | |
gmann3001 Fanatic
| Subject: Re: I hope somebody can help me... Wed Jun 06, 2012 9:14 pm | |
| Not really, the wires are broken right in the middle. i cant get the boot far enough over for good access. | |
Z-type Aficionado
| Subject: Re: I hope somebody can help me... Wed Jun 06, 2012 9:18 pm | |
| No sir, no harness plug under the dash. That being said though, it's not as bad as you think to disconnect all the switches and sensors and pull the harness out of the door for repair. Label all the ends to what they connect to, pull it through from the door, and you should be able to move the boot out of the way enough to repair the broken wires. The hardest part, honestly, willbe getting all the sensor and switch ends back in the door, but don't let it scare you. I think that's probably the best way to go, but I could be wrong . Anyone else? | |
| Subject: Re: I hope somebody can help me... Thu Jun 07, 2012 2:13 pm | |
| - Z-type wrote:
- No sir, no harness plug under the dash. That being said though, it's not as bad as you think to disconnect all the switches and sensors and pull the harness out of the door for repair.
Anyone else? Sounds like you've got the right approach. Get the slack from removing the door components, it's probably easier than disassembling the dash side. | |
gmann3001 Fanatic
| Subject: Re: I hope somebody can help me... Thu Jun 07, 2012 5:54 pm | |
| Thanks guys! I had considered doing it that way but was hoping for an easier way... I guess that's this weekends project. | |
MFFDVR Amateur
Name : Chris Age : 44 Location : Omaha, NE Joined : 2012-03-06 Post Count : 38 Merit : 0
| Subject: Re: I hope somebody can help me... Thu Jun 07, 2012 7:14 pm | |
| When running wire from my amp to the door speakers i found that the previous owner had cut the boot and managed to slice a handful of wires. I was able to repair the wires with the boot off. Only came off because it was already cut. Disassemply of the door panel wasn't too complicated, though. Probably worth it if you don't want to damage the boot. | |
| Subject: Re: I hope somebody can help me... Fri Jun 08, 2012 6:10 pm | |
| - gmann3001 wrote:
- Thanks guys! I had considered doing it that way but was hoping for an easier way...
I guess that's this weekends project. Naah - it's tedious but that tedium is really the only problem... | |
gmann3001 Fanatic
| Subject: Re: I hope somebody can help me... Fri Jun 08, 2012 8:09 pm | |
| Well I had the door apart last Aug. to do the speakers so I don't think it will be to hard. | |
| Subject: Re: I hope somebody can help me... | |
