 How to test blower motor module in 95
2 posters
Iron12
How to test blower motor module in 95 Empty
PostSubject: How to test blower motor module in 95   How to test blower motor module in 95 EmptyWed May 30, 2012 7:46 am
The auto climate control worked intermittently for one day and than the fan stopped altogether. Does anyone know what test I would use to determine if its the blower control module or the actual head unit itself. I checked all of the fuse (including under the rear seat) and they were all good.
Thanks.
PostSubject: Re: How to test blower motor module in 95   How to test blower motor module in 95 EmptyWed May 30, 2012 10:28 am
Easiest test without getting to involved is to just turn on your blower motor. Then tap on the blower motor lightly with a small hammer. In most cases if it is the blower motor it will start running again, but that a very good sign they have shyt the bed.
Iron12
PostSubject: Re: How to test blower motor module in 95   How to test blower motor module in 95 EmptyWed May 30, 2012 12:36 pm
Blower motor is fine. I disconnected the supply from the Riviera and threw 12 volts from another source and it started blowing immediately. Is their a way to test the control module? Also I see a lot of modules available with the same pin pattern but different mounting patterns that fit other GM products, I would imagine these would work but would like to know if anyone else has tried this approach.
Iron12
PostSubject: Re: How to test blower motor module in 95   How to test blower motor module in 95 EmptyWed May 30, 2012 4:57 pm
I found one on eBay for $35 with shipping from DKIautoparts. Hopefully it works longer than a week but for the price I couldn't pass it up.
» Write-Up: Blower Motor Control Module Replacement
» FAQ: HVAC Blower motor only works part time, or stays on
» location of blower motor resistor
» Blower motor removing and installing?
» How is this water getting in the Blower Motor(2000 Regal)?
