| high output alternator? | |
+18OntarioRivi 1998 Riv wrestler236 mdhall1 sqrivi Ryan from Ohio deekster_caddy Rickw EASHER Mr.Riviera jimmyriv 2toneRivi NO 4 EVR supercharged_riv07 SpaceBar oldsman105 AA steel2040 22 posters |
| Subject: Re: high output alternator? Thu Apr 09, 2009 3:38 pm | |
| From what research I did a while back regarding upgrading the alt. to a higher amp output required adding an external rectifier on the back of the alternator case. This cannot be done on our cars because there is no clearance between the alternator and the supercharger. Look at this site: www.alternatorparts.com for a visual of the high output rectifier and they also address the diameter of cable needed and specific wiring instructions.
The only thing I found was NAPA offers a reman. replacement with 150 amp output. | |
| Subject: Re: high output alternator? Thu Apr 09, 2009 4:16 pm | |
| - wrestler236 wrote:
- 200 to 240 amps
Planning on loading up with electronics? | |
wrestler236 Special
Name : Paul Location : Springboro, OH Joined : 2009-04-09 Post Count : 7 Merit : 0
| Subject: Re: high output alternator? Thu Apr 09, 2009 8:52 pm | |
| absolutely! I need to run a precision power pcx1500 amp at 3 ohms and two audiobahns an a2301t and an a2601t both at 4 ohms and i don't need those lights dimming on me. | |
| Subject: Re: high output alternator? Thu Apr 09, 2009 9:42 pm | |
| and a capacitor or 2 wont take care of that? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
wrestler236 Special
| Subject: Re: high output alternator? Fri Apr 10, 2009 1:20 pm | |
| Hmmm maybe I already have a 1.5 Farad cap and I had the same exact equipment in a 1990 Caprice Classic (man I miss that car...) I put a 180 amp alternator in that and I still had some dimming especially at stop lights lol At this point another cap or two might be easier and / or cheaper Im thinking, however I'm not sure if that will be the best solution | |
| Subject: Re: high output alternator? Fri Apr 10, 2009 1:25 pm | |
| What you want to try first is to overdrive your alternator with a smaller pulley, not go bigger, 140 amp should be enough for most, but you need the alternator at speed when you are at idle. | |
wrestler236 Special
| Subject: Re: high output alternator? Fri Apr 10, 2009 1:37 pm | |
| Here are some sites with HO alternators for the Riviera:
http://www.alternatorparts.com/gm38_conversion_cs144.htm
http://www.excessiveamperage.com/price_quote.htm I don't think they ever quoted me
http://www.highoutputalternator.com/ Quoted: 220 amp @ $589
http://www.db-starter-alternator.com/Alternators/High%20Output/Buick/ Quoted: 220 amp @ $229
http://www.powerbastards.com/products.asp?cat=2488 Quoted: 240 amp @ $265
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260348027103&viewitem=#ht_1429wt_1191 This guy on ebay is selling upgraded stock version 200 amp @ $159 | |
wrestler236 Special
| Subject: Re: high output alternator? Fri Apr 10, 2009 1:41 pm | |
| yeah ive been reading up on trying a smaller pulley with that link from alternatorparts.com that Rickw posted, and it seems like a pretty janky way of doing things, because if you rev the engine too hard it will damage the alternator (how hard is too hard anyway?) , I may try something like that if I go with an upgrade that isn't cutting it in idle But it is still an option none the less...
I don't know if 140 amp will cut it in my situation anyways... I'll have one amp 2 x 75 rms watts rated @ 12v or (2 x 150 peak); another amp 2 x 150 rms watts @ 12v or (2 x 300 peak); finally 1 x 750 rms watts @ 12v or 1 x 1500 peak the two 2-channel amps will be running at 4 ohm impedance and the 1-channel amp will being running at 3 ohm impedance, more than likely the car will being running between 14.4v to 12v of course, but I would like to keep it as close to 14.4v as possible so as to not dim the headlights
Does anyone feel like doing the math for that? lol | |
Ryan from Ohio Fanatic
Name : Ryan Location : Toledo, Ohio Joined : 2008-11-16 Post Count : 307 Merit : 7
| Subject: Re: high output alternator? Sun Apr 26, 2009 1:07 pm | |
| www.motorcityreman.com
Give them a try.
Also try Nate @ Excessive amperage again. Give him a call if he doesnt respond to email. Sometimes it works better. | |
OntarioRivi Rookie
Name : Mike Age : 40 Location : Ontario,Ca Joined : 2008-09-13 Post Count : 13 Merit : 0
| Subject: Re: high output alternator? Tue Apr 28, 2009 5:52 pm | |
| To anyone wanting to go to a bigger alternator i would strongly recommend ensuring proper connections, upgrading your wiring and a good battery and capacitor.. I'm running about 2000watts RMS in total. Ive had this setup for about a year now and still have had no issues with voltage or the stock alternator dying. Just my opinion.[/img] | |
| Subject: Re: high output alternator? Fri May 29, 2009 10:00 pm | |
| - OntarioRivi wrote:
- To anyone wanting to go to a bigger alternator i would strongly recommend ensuring proper connections, upgrading your wiring and a good battery and capacitor.. I'm running about 2000watts RMS in total. Ive had this setup for about a year now and still have had no issues with voltage or the stock alternator dying. Just my opinion.
Upgrading stock wiring is a MUST in any car before money is spent on a HO alternator. Doing the "Big 3" in our cars has to be a REAL treat. In case you arent aware, thats the Alternator to battery, Battery to ground and Motor to ground. If Nate @ Excessive did not get back with you give him a call. Hes a busy but good dude. Nate also has overdrive Pulleys available. They are custom made, he is the only person on the planet with these. I put one on my Alero and its a nice increase of voltage! | |
mr riviera Member
Name : Pat Location : Syracuse Joined : 2007-10-18 Post Count : 96 Merit : 0
| Subject: Re: high output alternator? Sun May 31, 2009 1:54 am | |
| Ive been runnin stock alt with 1000 watts for years now ... no probs... and dont have a cap either ... 1 Infinity 110x4 plus a crunch p2250 bridged rated at 1000 itself , dont know about that claim but its makes my Kicker Comp cvr 10 ( rated @600, thats where i got my 1000 watts from ) pound pretty good | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 11:42 am | |
| I rebuilt my alternator with new bearings and a HD bridge rectifier from www.alternatorparts.com. I am also going to get an overdrive pulley, as even all that stuff done I still have voltage drops at idle. | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 11:52 am | |
| - deekster_caddy wrote:
- I rebuilt my alternator with new bearings and a HD bridge rectifier from www.alternatorparts.com. I am also going to get an overdrive pulley, as even all that stuff done I still have voltage drops at idle.
Have you been able to fix the "Noise" after rebuild? Also, It's good to know that you are experiencing a voltage drop at idle. Not good for you, but what I mean is, now I know I will have to address that issue also after rebuilding my alternator. Have you done any research into what diameter pulley to use for the alternator, so i can just order one along with all the rebuild parts.????? | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 12:27 pm | |
| Yes Rick, all this reminded me to go order the OD pulley. The stock pulley is I believe 62mm diameter. They sell that and a 54 mm pulley at alternatorparts.com, I just ordered the 54mm pulley. | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 12:34 pm | |
- Nope, shouldn't hurt anything. You could also consider upgrading the alternator - I rebuilt my own with new bearings and a HD bridge rectifier from www.alternatorparts.com. I am also going to get an overdrive pulley, as even all that stuff done I still have voltage drops at idle.
What did you do to correct the noise issue.??? Am anticipating same problem after rebuild and would like to be prepared for possible problem. | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 12:52 pm | |
| I discussed that with the guy from alternatorparts and he said it shouldn't make any noise, and possibly the internal capacitor is deteriorating. He said to go to RS and get a capacitor, and put it on the positive post outside the alternator, and that should take care of it. I'll let you know how that works out. | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 12:56 pm | |
| What type or capacity/ part number capacitor would you have to buy. ? There are different ratings in micro farads (mf) ? Did he specify.? | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 2:27 pm | |
| He did not specify. I'm going to have to go by looks on it - it should be a single post, I'd guess about an inch tall or so. | |
97 park ave Addict
| Subject: Re: high output alternator? Fri Oct 30, 2009 2:47 pm | |
- He did not specify. I'm going to have to go by looks on it - it should be a single post, I'd guess about an inch tall or so.
it is a 1 amp diode from radio shack from what i understand, 98riviera98 posted this link to another thread: https://rivperformance.editboard.com/audio-electronics-f7/write-up-stage-i-voltage-booster-t1610.htmand in that thread there was another link to zzp about the DIY voltage booster, go to this link and read it gives you a pretty good idea of what to do: https://www.zzperformance.com/grand_prix/articles1.php?id=48 | |
97 park ave Addict
| Subject: Re: high output alternator? Fri Oct 30, 2009 2:53 pm | |
- You could also consider upgrading the alternator - I rebuilt my own with new bearings and a HD bridge rectifier from www.alternatorparts.com.
do the rivieras have the cs130d also? which kit did you get? | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 3:52 pm | |
| Rivs have the newer style large body CS144.
Their website is very difficult to navigate, but here are the last things I ordered:
Part No. 63034N
63034N 1 $9.95 $9.95 Part No. 8122
8122 1 $9.95 $9.95 Part No. 391083
391083 1 $9.95 $9.95 Part No. DR5180PF, Heavy Duty Bridge Rectifier, Fits: Delco CS-144 alternator
DR5180PF 1 $44.95 $44.95
The last item is the HD bridge rectifier, the other items are two bearings and new brushes. I used my arbor press for the bearings, and was a little troubled at how the front bearing replaced - there was a hardened sleeve around the old one that cracked, I just put a little locktite on the outside of the new bearing before I pressed it in. I don't know how you would do it without a press.
http://store.alternatorparts.com/search.aspx?find=DR5180PF | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 4:19 pm | |
and in that thread there was another link to zzp about the DIY voltage booster, go to this link and read it gives you a pretty good idea of what to do: https://www.zzperformance.com/grand_prix/articles1.php?id=48 Your talking 2 different things. The diode fakes the alternator to produce more voltage at idle. The Capacitor is for noise or static that you may hear in the radio. There is a capacitor inside the alternator with it's own P/N and can be changed during rebuild. Derek just did not buy that particular capacitor because he wasn't having any noise issues before the rebuild. So the easy way to correct for that now is to add an inexpensive one externally. Also, this vendor does not offer a rebuild kit for the CS144, you have to order the individual parts. They are still less expensive than NAPA. | |
| Subject: Re: high output alternator? Fri Oct 30, 2009 4:40 pm | |
How about a condenser from an older style distributor with points. Such as a Chevy 250 ci, 6 cylinder from the 60's to 70's. They must still be available at the auto parts store or that box under your bench.???
| Subject: Re: high output alternator? Fri Oct 30, 2009 4:43 pm | |
How about a condenser from an older style distributor with points. Such as a Chevy 6 cylinder. They must still be available at the auto parts store or that box under your bench.??? Probably just the thing... I'll see what happens. | |
| Subject: Re: high output alternator? | |
