 torque specs
Pipes
Pipes
torque specs Empty
PostSubject: torque specs   torque specs EmptyTue Jun 26, 2012 8:41 pm
Does anyone know or where I can find torque specs for the series 1? I only can find the series 2 specs online
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyTue Jun 26, 2012 8:48 pm
Perhaps another member knows of an online source, but...
I have FSM for a Series I. Perhaps I can scan and send.
A glance at the index, I don't see a complete listing for them.
What specifically are you looking for?
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyTue Jun 26, 2012 9:02 pm
torque specs for what?
Pipes
Pipes
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyTue Jun 26, 2012 9:54 pm
Im rebuild the bottom half of the engine now and I want to make sure everything is right.
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyWed Jun 27, 2012 8:45 am
Although not quite as reliable as the FSM, I've found the Haynes manuals have pretty good torque specs. How did you get the spec for the bearing clearances? Should be able to get torque specs from the same source.
pbrktrt
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyWed Jun 27, 2012 7:34 pm
Any NAPA store should be able to print the torque specs from Mitchell on Demand. It's part of our system anyway and worth checking out. You are gonna need oil and a filter anyway. smile
Pipes
Pipes
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyThu Jun 28, 2012 7:47 pm
Ok I will try napa tomorrow when I get to work. I'm wondering if alldata vot any info on our cars yet because a few years ago they didnt have nothing about rivieras.
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyThu Jun 28, 2012 7:53 pm
Recommend that you invest in a full set of factory manuals (ebay).
Assembly procedures have torque specs listed after each and every step.
Unfortunately, there is not a master list. To do that would be a master task.
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyFri Jun 29, 2012 7:34 pm
FYI,
I came across this craigslist ad for the manuals you might be looking for.
http://cnj.craigslist.org/pts/3042331993.html
Pipes
Pipes
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyFri Jun 29, 2012 8:56 pm
Thanks for link denim
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyFri Jun 29, 2012 9:13 pm
Your welcome.
I think you can get them for less. The photo is dated from Jan.
After all, craigslist is not eBay.
Good luck.
cryoburned
torque specs Empty
PostSubject: Re: torque specs   torque specs EmptyTue Apr 30, 2013 5:23 am
I'm also looking for some torque numbers. I'm planning on doing a head gasket on my 95 S/C this weekend, so I'd need..
Head bolt torque sequence and torque spec
Exhaust manifold sequence and torque
same for the valve covers, LIM, and supercharger.
Also planning on replacing the supercharger coupler, what are the torque figures on the snout bolts?
I looked it up, I found a Haynes manual for buicks and pontiacs 90-95 or whatever, but.. it says for all full size "excluding RWD and supercharged models." Go figure.
torque specs Empty
torque specs
» 12hp briggs and stratton flat head torque specs
» lug nut torque
» 2510 diesel Mule engine repair...........
» Speaking of lugnut torque?
» tire swap on TORQUE (ford/craftsman)
