| Is my alt wire messed up? | |
dreww Junkie
| Subject: Re: Is my alt wire messed up? Tue May 29, 2007 11:55 pm | |
| if I can remember, mine is routed under the supercharger snout.
just tucked it back under there when I put the alternator back on last. | |
| Subject: Re: Is my alt wire messed up? Wed May 30, 2007 8:25 am | |
| That's the way mine was stock, exactly like yours. I put split loom on mine and routed it under the plug wires and wiring harness, but still over the blower. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
98riv Moderator
| Subject: Re: Is my alt wire messed up? Wed May 30, 2007 11:12 am | |
- That's the way mine was stock, exactly like yours. I put split loom on mine and routed it under the plug wires and wiring harness, but still over the blower.
_________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Is my alt wire messed up? Wed May 30, 2007 11:19 am | |
Yeah, the loom appears to have a bigger clip to hold this wire as a stock location. I might have to pull it off and run it back under the plug wires. With the shield on in the winter, it rubs on the wire, and has worn a small notch in it. | |
| Subject: Re: Is my alt wire messed up? Wed May 30, 2007 11:52 am | |
| Instead of disconnecting the alt wire, you can disconnect your plug wires from the coils and tuck it under them. Up to you, some don't like to touch the plug wires, but I pull them off quite a bit. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Is my alt wire messed up? Wed May 30, 2007 1:52 pm | |
| that would be the easy way... | |
99Rivman Aficionado
| Subject: Re: Is my alt wire messed up? | |
