 Matt's SC 97 Riviera
Matt's SC 97 Riviera - Page 5 Empty
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 7:27 am
With stock valvesprings, just be aware and careful about higher RPMs. Avoid redline if you can. The additional lift requires a little additional force to get the valves closed in time, so your redline should be a little lower than it was before.
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 10:55 am
What would you say my max safe RPM would be then? 5500?
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 11:25 am
It's impossible to know how worn your OE valvesprings are, or at what RPM they may start to float. I have heard of others installing 1.9s on stock springs, so you aren't the first and maybe you'll be fine for a while. Just be aware that you could be _very_ close to float at the stock redline.
that said, 5500 should be plenty safe.
I found when I was on 1.9s with a 3.4 that it didn't pull so hard at 6000 anyway, so I set my shift points to 5700 (I did have the 90 lb springs), preferring to keep the engine closer to the torque peak.
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 11:39 am
Agree with deekster. My dyno graph peaked around 5300 RPM and stayed almost flat to 5700. No need to rev much higher unless you add more breathing/exhaust mods. Shifting from 1st to 2nd gear puts you around 3500 RPM, where there is plenty of torque available from the 1.9s. Mine is set to shift around 5700-5800 depending on the situation. Holding shifts to 6k might give a slight hpower advantage from running out the gear, but not worth the risk for wear & tear, imo. Not without beefier springs, anyway.
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 12:12 pm
Since this car is a daily driver, I rarely go past 5K anyway, so I hope I'm good for a while. 5500 is fine with me for now. I can tell my exhaust is holding it back somewhat, so I'm looking forward to seeing what my headers will do for it. I'm not exactly looking forward to installing them. Haha. I would be with a lift.
Merit : 122
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 3:12 pm
Matt's SC 97 Riviera - Page 5 Isitgreen
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Nov 26, 2012 3:31 pm
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyWed Nov 28, 2012 2:17 am
Nearly hit WOT today. WOW, I can not belevie how fast this car is now, it's unreal. I did hit around 5900RPM and I didn't notice any valve float. I was seeing 9PSI at that time. But I find it unusual that not once since I started scanning a few months ago, have I seen any KR show up. Nothing.
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyFri Nov 30, 2012 3:08 am
Not doing the calipers. frown
Merit : 64
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySat Dec 01, 2012 12:49 pm
Nice. It's coming together very well.
c0reyl
c0reyl
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 02, 2012 2:17 pm
How were the price on those calipers and how do they perform compared to the stock riv? I was always very happy with the stock braking performance of my riv
Also I'd love to see some numbers on how fast at thing is some time lol smile
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 02, 2012 2:45 pm
Info on F-Body calipers can be found here:
http://rivperformance.editboard.com/t2310-write-up-f-body-brake-mod
Please read and feel free to post any questions or opinions in the thread.
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 02, 2012 10:43 pm
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySat Dec 22, 2012 10:21 pm
Friday was the first day of snow on the ground here. I quickly found out that I had zero traction with my cracked/dry rotted and pretty worn tires. I knew I needed new tires, I was just trying to wear them out some more before I replaced them. Well today I went straight to BJ's and bought 4 new tires and had them installed. They are Michelin defenders, 90k mile tires. Expensive but top of the line tires. Drives better overall now slightly, and huge improvement in the snow/ice. Before If I tried to stop any faster then slowly, the tires would instantly lock up in the snow. Don't have that problem now. smile
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyThu Jan 10, 2013 2:12 am
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Feb 03, 2013 9:14 pm
Belt issue fixed.
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyWed Nov 27, 2013 3:44 am
This car is now up for sale, as I have bought a new car and I'm moving on.
h20man
h20man
Merit : -2
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 01, 2013 10:16 pm
after all of that work your selling it? confused
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 01, 2013 10:30 pm
http://rivperformance.editboard.com/t10598-putting-up-my-97-riv-sc-for-sale
whud ya buy?
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 01, 2013 10:44 pm
"I have bought a new car (2012 Cruze ECO)"
h20man
h20man
Merit : -2
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptySun Dec 01, 2013 11:31 pm
Didn't see that the cruze is a nice car I just couldn't Imagine getting rid of my riv with all the money I put into it so far
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Dec 02, 2013 12:56 am
tz.....
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Dec 02, 2013 2:24 am
Yes I have alot of time and money into it, MUCH more then it's currently worth, but in the end it's still an old car that doesn't have much value. What would I do with it? It would just sit. It'll need more money put into it to make it really nice again, and assuming I put a few more thousand dollars into it, I would still end up with a 17 year old car with bad gas mileage.
h20man
h20man
Merit : -2
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Dec 02, 2013 9:59 am
Well looks like you have a it figured out, good luck with the sale I bet your gonna miss the power of the riv though
Mattwa
PostSubject: Re: Matt's SC 97 Riviera   Matt's SC 97 Riviera - Page 5 EmptyMon Dec 02, 2013 1:57 pm
Thanks, no I won't miss the power once my current project is finished (another reason why I don't really have a use for this car anymore). I'm building a Turbo 3800 with a 6-speed manual in my 1986 Pontiac Fiero. 500HP is my goal, 400WHP should be an easy start. smile
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Matt Spezza
» Matt Beckenham relishes the Pro scene
» Matt Hargreaves has his sights on Keilor Gift
» Matt Shirvington in fast lane with the Dragons
