 injectors and gas questions.
c0reyl
c0reyl
injectors and gas questions. Empty
PostSubject: injectors and gas questions.   injectors and gas questions. EmptySun Jul 22, 2012 8:16 pm
So, series I L67, what injectors, fuel rails, and fuel pump does it have?
What out of those are an upgrade from my stock L36?
Also, given hypothetically,10 PSI in the intake manifold of an L36 assuming you got peak torque at 3500 rpm, and was intercooled, how would that affect atomizing fuel, and would it increase MPG? would increasing the duel efficiency also increase power output at all from Volumetric efficiency gains?
Merit : 122
PostSubject: Re: injectors and gas questions.   injectors and gas questions. EmptySun Jul 22, 2012 8:29 pm
injectors 29lbs.
fuel rail, the series one fuel rail. the one that fits on the m62.
Fuel pump is same as stock series 2 L67.
And the rest is speculation. I'd inject after the intercooler though.
c0reyl
c0reyl
PostSubject: Re: injectors and gas questions.   injectors and gas questions. EmptySun Jul 22, 2012 8:36 pm
Karma wrote:
injectors 29lbs.
Hypothetical IC would sit on top of LIM grimace
Then the injectors would be under it
» Garmin 610 Questions
» 2010 preseason trivia questions.
» Couple of questions about rumors...
» Pulley Question
» Timing question on 4500
