 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)
oldmanriver
95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) Empty
PostSubject: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptySun Jul 29, 2012 11:00 pm
I will have to start the Riv two to three times listen to it struggle to idle. When it does its smooth, but very hesitant when I get on the gas. I don't hear the SC whine and it seems to struggle for air. I have everything I can third of from where I stand, what I know, and some help. No check engine light. No codes. Just runs like shit!!
Any help/feedback would be appreciated, thanks. OMR
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptySun Jul 29, 2012 11:22 pm
Welcome! the SC whine isnt always noticable with the stock air box. Symptoms sound like bad fuel pump maybe? also, the cars exhaust sounds like the car is struggling for air at low revs once the Catalytic Converter wears out. The cars mileage may help someone here diagnose it?
oldmanriver
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyMon Jul 30, 2012 7:53 am
125k mi I used to be able to hear and feel when the SCSI would do its job, but nothing now. I don't know if its the SC or something from preventing it to work. I have to feather the gas to get around... Forget about gettin on it to downshift or climb a hill
pbrktrt
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyMon Jul 30, 2012 7:35 pm
When's the last time you changed the fuel filter? Have you checked rail pressure? It sounds like it's starving for fuel.
oldmanriver
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyMon Jul 30, 2012 11:05 pm
haven't change the fuel filter but got good pressure @ the rail. Wires are good new plugs, had a buddy do all he could, by checking all he could regarding electrical systems with a voltmeeter and seeing if the output was correct per component. He recommends a mapscope because he found nothing abnormal and no check engine light. I need some help from the Rivi forum to help save me the $ I don't have. College tuition gotta come first, I will ONLY ride the bus if I have to!! I want the Riv back to the hitch she used to be
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyTue Jul 31, 2012 12:49 am
When you say "wires are good", you mean they've been replaced with brand new, genuine AC Delco wires, right?
oldmanriver
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyTue Jul 31, 2012 10:32 am
No. A mechanic friend said they were, so I took his word. I have had spark related problems in the past, this doesn't seem to be a spark issue.
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyTue Jul 31, 2012 10:37 am
Just my .02. If your engine has close to 100k miles, and you don't know when the last time the wires were changed - and you plan fix the problem and drive this car in the future - I'd drop $35 and order some new GM wires. It's just a good thing to do for maintenance purposes, even if it's not causing the problem.
When my first set of wires failed, they looked 100% perfect. I still don't know which one went bad. And I don't care - my problem disappeared, so I was happy!
oldmanriver
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyTue Jul 31, 2012 12:22 pm
Good advice. I plan on keeping it and when I get shit in order I plan on doing a lot of work in it. Always loved the The Rivs
96riv
96riv
PostSubject: Re: 95 sc Riv.... starts the dies... no power...hesitant... hard (hot start)   95 sc Riv.... starts the dies... no power...hesitant... hard (hot start) EmptyTue Jul 31, 2012 3:20 pm
Ohm your plug wires to find out if they are bad. I have found bad wires this way.
http://www.arizonagn.com
» 15.5 hp turbo cooled craftsman briggs and stratton wont start
» 8.5 hp Briggs Snoblower Surges then Dies
» Power Mods ????
» power chips or modules
» Power Plays
