| Antenna replacement, Aftermarket? | |
matt270avian Expert
Name : Matt Age : 22 Location : Frederick, MD Joined : 2012-01-15 Post Count : 2680 Merit : 53
 | Subject: Re: Antenna replacement, Aftermarket? Sun Apr 13, 2014 11:48 pm | |
| Just so you all know the eBay ones like the one linked on the first page absolutely suck. I can hardly pick up anything with it, but I figured the $5 I spent on it isn't worth trying to argue with anyone over. I just ordered the Metra 44-UA200 because it seemed to be the best hidden antenna based on misc. reviews. I plan on placing it pretty much exactly how Robo has his. The Metra unit is amplified and has an additional ground wire. Some people say that they have better luck without hoking up the amplifier, others do, and the rest see no difference. I'll post which way works best for me. |
llamalor2112 Junkie
Name : Evan Age : 26 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 851 Merit : 13
 | Subject: Re: Antenna replacement, Aftermarket? Mon Apr 14, 2014 12:12 am | |
| For everyone who experiences a dropped mast (motor runs but cable that lifts mast is snapped) contact Barney Eaton on the aaca forums. He repairs these antennas with metal cables replacing the stock plastic ones. Great guy. |
Name : robotennis Age : 57 Location : las vegas Joined : 2007-12-17 Post Count : 5561 Merit : 142
 | Subject: Re: Antenna replacement, Aftermarket? Mon Apr 14, 2014 1:23 am | |
| Mine works ten times better than the OEM antenna on it's best day.Really! I get stations that I couldn't get before and clearer.No lie |
stan Aficionado
 | Subject: Re: Antenna replacement, Aftermarket? Mon Apr 14, 2014 1:46 am | |
| ..but c`on folks.Do you really listen that much to radio?....i always listen to CDs......haha. |
llamalor2112 Junkie
 | Subject: Re: Antenna replacement, Aftermarket? Mon Apr 14, 2014 2:46 am | |
| Cd's?? What the hell are c d 's?? I only listen to lossless ogg vorbis audio files cuz, ya know, it's so hip  See: sarcasm |
stan Aficionado
 | Subject: Re: Antenna replacement, Aftermarket? Mon Apr 14, 2014 4:22 am | |
| that's cool Evan,you can listen to whatever files you want to.I asked if you listened to radio?..haha |
llamalor2112 Junkie
 | Subject: Re: Antenna replacement, Aftermarket? Mon Apr 14, 2014 4:57 am | |
| I was messin anyhow and I do listen to radio often enough to actually warrant a good antenna. A few really good local stations in Seattle |
al_roethlisberger Junkie
Name : Al Roethlisberger Age : 50 Location : Sanford, NC Joined : 2013-03-12 Post Count : 941 Merit : 22
 | Subject: Re: Antenna replacement, Aftermarket? Tue Apr 15, 2014 9:52 am | |
| You can get used power antennas from any pick-and-pull for $15-30, usually guaranteed for 30 days.
An antenna from a number of GM products will fit with a little modification (bracket, gasket from old one), and of course one from a Riv or Aurora (if I recall) bolts right on. I always pull one from any Riv/Aurora when I'm at a yard unless I already have 2 or 3 lying around already.
matt270avian Expert
 | Subject: Re: Antenna replacement, Aftermarket? Tue Apr 15, 2014 10:43 am | |
| I went through a few junkyard antennas. The people always swapped them out when they broke until I just said enough. I think I pulled mine from Auroras. |
matt270avian Expert
 | Subject: Re: Antenna replacement, Aftermarket? Tue Jun 02, 2015 4:10 pm | |
| Has anyone ever installed a fixed mast antenna? I'm thinking about just grabbing a little stubby one and calling it job done. Maybe even a shark fin if somebody knows how to install one.
Sorry Charlie, but the one you sold me gave up and won't go all the way up/down anymore. Might have something to do with repeated trips to triple digit speeds....... |
charlieRobinson Expert
Name : Charlie Age : 33 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3921 Merit : 30
 | Subject: Re: Antenna replacement, Aftermarket? Tue Jun 02, 2015 10:52 pm | |
| - matt270avian wrote:
- Has anyone ever installed a fixed mast antenna? I'm thinking about just grabbing a little stubby one and calling it job done. Maybe even a shark fin if somebody knows how to install one.
Dang. Im sorry to hear that. Both ,the radio and antenna I shipped to members have been reported to fail  :seppuku: |
matt270avian Expert
 | Subject: Re: Antenna replacement, Aftermarket? Tue Jun 02, 2015 11:56 pm | |
| It's no big deal, it lasted longer than every other one I've had (that I can remember). |
matt270avian Expert
 | Subject: Re: Antenna replacement, Aftermarket? Mon Aug 31, 2015 10:46 am | |
| The stock fixed antenna out of a Cavalier drops right in (I pulled mine off a '96). The mast fits perfectly into the stock rubber piece on the body and the antenna cable plugs right in. The only issue is a metal bracket needs to be fabbed to hold it in place, but it shouldn't be hard to make at all. |
matt270avian Expert
XCELLR8 Amateur
Name : Kent Age : 50 Location : Central IL Joined : 2015-10-09 Post Count : 26 Merit : 0
 | Subject: How does the guts of power antenna work? Fri Oct 16, 2015 10:54 am | |
| My antenna will raise the mast up, but not down. I can assist it down about 3/4 of the way before it kicks out, then it will raise itself when powered. I hear some clicking and grinding like some gears are not meshing, but not sure how the guts of the antenna work. Anybody have any insight to my issue. |
Name : Scott Location : Macomb, Michigan Joined : 2010-02-24 Post Count : 4275 Merit : 179
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 10:55 am | |
| - XCELLR8 wrote:
- Anybody have any insight to my issue.
Buy a new one. You aren't fixing it. It happens to all of us eventually. Mine lasted 16 years and 160k before it started doing exactly what yours is.... |
XCELLR8 Amateur
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 12:01 pm | |
I've read through some old posts, but what are the options today besides junk yards. Thanks |
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 12:13 pm | |
XCELLR8 Amateur
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 7:02 pm | |
| - robotennis61 wrote:
- I bought this one or one similar and it works better than the OE antenna by far.
http://tinyurl.com/ptcbd4b
Thanks for the link. My plan is to go with another power unit, unless I can not find one. |
98riv Moderator
Location : USA Joined : 2007-01-14 Post Count : 967 Merit : 30
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 7:43 pm | |
| If you scroll down towards the bottom at this link you can see what is inside of the antenna. It isn't the exact one that came on our cars, but the inside looks the same http://www.grail-ss.com/PowerAntennaR&R.htm . They are pretty simple inside. I took mine apart last weekend and it had a bunch of old grease in it that I cleaned out. The plastic mast cable broke in mine last winter. I just ordered a replacement cable from http://antennamastsrus.com/GM/Buick/Riviera/Riviera%201995-1999.htm and plan on replacing it tomorrow. It looks exactly like the one that came on the car, so hopefully it will work. My problem is different than yours, but it wouldn't hurt to take it apart and see what it is doing. You will have to drill out the rivets to get it to open. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
stan Aficionado
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 8:31 pm | |
| I've been thinking to disconnect mine see how it is without an antenna. Makes the car look outdated. |
XCELLR8 Amateur
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 16, 2015 9:47 pm | |
| - 98riv wrote:
- If you scroll down towards the bottom at this link you can see what is inside of the antenna. It isn't the exact one that came on our cars, but the inside looks the same http://www.grail-ss.com/PowerAntennaR&R.htm . They are pretty simple inside. I took mine apart last weekend and it had a bunch of old grease in it that I cleaned out. The plastic mast cable broke in mine last winter. I just ordered a replacement cable from http://antennamastsrus.com/GM/Buick/Riviera/Riviera%201995-1999.htm and plan on replacing it tomorrow. It looks exactly like the one that came on the car, so hopefully it will work.
Thanks for the links. They were very helpful!! |
matt270avian Expert
 | Subject: Re: Antenna replacement, Aftermarket? Sun Oct 18, 2015 11:42 am | |
| Honestly for that price you're better off just snagging a few from the junkyard. They charge about 15 bucks a piece here, and some places will even give you a warranty on them so you can just exchange it if it breaks. |
albertj Guru
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 7111 Merit : 137
 | Subject: Re: Antenna replacement, Aftermarket? Fri Oct 30, 2015 6:07 pm | |
OR get a good used one from Ed Morad, moradpartscompany.com |
RivieraRyan Enthusiast
 | Subject: Antenna Mast? Mon Oct 24, 2016 12:00 pm | |
| My antenna stopped retracting so the dealer said to replace it. I was able to get a new motormotor, but am having a hard time locating the Mast. Any help finding OEM part# 19151301 is much appreciated. |
 | Subject: Re: Antenna replacement, Aftermarket?  | |
