 Riv A/C
2 posters
CMan
CMan
Riv A/C Empty
PostSubject: Riv A/C   Riv A/C EmptySun May 20, 2007 7:17 pm
Got a question for you guys. In the Riviera, the air doesn't work. But, if you unhook the battery and then hook it back up, it works for the time that you have the car running. If you shut it off, and then turn it back on, the A/C won't work again.
Tried replacing the ambient air temp sensor and that didn't do anything...any ideas?
http://myspace.com/bkwallen
Riv A/C Empty
PostSubject: Re: Riv A/C   Riv A/C EmptySun May 20, 2007 7:40 pm
Maybe the Blower Control Module? It's under the dash, and has been known to fail on our cars. Also check the connector/wiring on the IAT sensor (airbox).
Riv A/C
