 Charlie Robinson's '99 Riv
Go to page : Previous  1 ... 12 ... 20, 21, 22, 23, 24  Next
Charlie Robinson's '99 Riv - Page 21 Empty
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyWed Apr 15, 2015 11:36 pm
Interesting.. I have not. I might just go ahead and blend them in. Thanks for that!
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 16, 2015 12:18 am
Daaaaaaaamnnnnnnnnnn.........super.
Merit : 122
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 16, 2015 9:50 am
How do I get the boost bypass butterfly out so I can remove that external rod so I can polish around it easier?
Take the screws out, slide the plate out. Gently pull the lever part out. It will slide out of the bearings. Stuff the bearings with some paper towel or sometime to keep the chips out, you don't want to try finding and pressing in new ones.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 16, 2015 10:00 am
Your gen V looked incredible Scott. Someone was very happy to buy that I'm sure.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 16, 2015 10:30 am
That's a negative Ghost Rider. I still have it.
Karma is dead on. You have to take that plate off before you can slide the rod out.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 16, 2015 12:00 pm
Oh dang. I thought you were planning on selling it?
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyWed Apr 22, 2015 9:25 pm
All the tiny bits should be here Friday. Getting all the cracks then time to blend and then finally polish. Thanks for the tip, Scott. I didnt even realize those were casting plugs until you said something. I hacked them off. Every gram counts with the fat ass fatty, right?
Havent even started the N* yet.. Need to get that rolling asap.
I got the bypass butterfly out today. I found one of the screws somewhat stripped and I finished it off. I had to dremel the philips into a straight edge to get the cursed thing out. Anything special about these screws? They have pinched ends. Never seen that before.
Charlie Robinson's '99 Riv - Page 21 Img_2020
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 23, 2015 8:28 am
They pinch the ends so that the screws can't back themselves out. Nobody wants a metal plate in their engine!
Yw on the casting lumps. Looks wayyyyy better with them gone.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 23, 2015 9:15 am
Thanks, Scott. I am going to have a find a replacement screw then. Do they have a special name or anything to help my search?
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 23, 2015 9:35 am
Maybe Karma can chime in on that one. Throttle plate screw? Technically, it is just a baby throttle plate.
I just looked at a TB from a new Terrain (heavy tech is pulling the engine). They redesigned the rod. They don't have those screws anymore, but the holes in the rod are oblong instead.
Actually, I just looked at my old S/C here on the bench. That rod/plate is intact. You want me to yank the screws and send 'em to ya? As long as they're the same from a Gen III to a Gen V....
Merit : 122
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 23, 2015 12:26 pm
Screws should all be the same.  Cutting a slot is common too, since the end crimp makes them so tight.  I always just reuse the screws and add red thread locker. But it would depend on how stripped the were when you removed them.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptySun Apr 26, 2015 9:19 pm
Thanks, Andrew. one screw is fine. The other one was toasted. I reckon I will take one out of the gen 3 when it comes off.
I started polishing the northstar throttle body today after working on the gen V for a bit. I am just able to see the finish line on the blower. At first, progress was fast but as I am just now seeing the end, the job is becoming quite arduous. I am switching between the smallest wire dremel bits I can find for the corners and sand paper to blend it all together. The little cracks and corners are challenging and everytime you think you get something right another pit shows its face.
Scott, I commend you on your finished product. Well done.
Anyone who does this has to be at least a little bit crazy.
I am currently on 180 grit and moving higher until its buff time. I didnt take any pictures from yesterday or today but I will get one after next session. I dont know the exact times but I feel like i've dumped a good amount of hours into this thing.
Here's a pic from a few days ago when I held it above the gen 3 to make sure its going to fit with clearance from the alternator. Ive found a few places on the net that say 99+ alternators and brackets will clear it and I wanted to make sure. Looks like I will have plenty of room to drop this bad boy in.
Charlie Robinson's '99 Riv - Page 21 Superc10
Merit : 135
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyMon Apr 27, 2015 12:36 pm
Yeah it really is never-ending it seems like. I knew from p&p'ing everything on the inside of the blower/lim/tb that I'd never try doing the outside of a blower case. haha You need to be high or have lots of shows to watch or something. I got through all the seasons of dexter while doing my blower and lim. I did it largely by hand. Also noticed that coarse paper pretty quickly turns into pretty good fine stuff after wearing away. I was constantly starting out to do heavier material removal and then I kind of found myself just polishing. Slowed me down big time I'm sure. Try to avoid that.
Anyway lookin good dude!
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyTue Apr 28, 2015 12:40 am
Thank you.  smoke for sure.
I am working on a mount for the stereo relocation. going to make a bracket and use the existing hole on one of the braces in the center console. I will get some pics of that soon.
Also going to make a mount for the wideband and Hpt module.
Charlie Robinson's '99 Riv - Page 21 Img_0410
Charlie Robinson's '99 Riv - Page 21 Img_0411
Charlie Robinson's '99 Riv - Page 21 Img_0412
Merit : 62
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyWed Apr 29, 2015 3:55 pm
That stereo will look nice sitting down where the CD's go.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyWed Apr 29, 2015 10:27 pm
Yeah, I love it in that spot. The only drinks I have in my car are usually gallon jugs of water behind the front seats.
Strict drink policy in the Riv nono
I've had the receiver down there for a while but just now giving it proper mounting. I'm going to have a plate to mount the tuner modules to also.
receiver mount. based on a very similar bolt up design i used on my S4 galaxy on the Vmax.
Charlie Robinson's '99 Riv - Page 21 Img_2021
Charlie Robinson's '99 Riv - Page 21 Img_2022
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyWed Apr 29, 2015 11:43 pm
Are you hard-mounting the hpt in the car?
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 30, 2015 9:29 am
medium mount. it will be attached to the bracket in the back of the console. I used to have it just laying back there. So kind of a step up. alien
Merit : 62
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 30, 2015 10:36 am
Charlie if you don't mind, could you give me a quick explanation as to what that HPT thingy is there? I can't say I've ever heard of it and I'm having a hard time seeing what it is in the picture.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 30, 2015 10:37 am
I'll save you chuck....
It's the Interface for his HPT tuner. Much like my DHP, only HPT. I'm guessing he's just mounting somewhere so that he can easily plug into it at any time.
Merit : 62
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 30, 2015 10:42 am
Oh, cool! Makes sense.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptyThu Apr 30, 2015 11:57 am
I like the idea of a soft mount. I just have mine tucked behind the front of the center console. It stayed there without budging during the autocross so I'm fine with it, plus it keeps the cable out of the way of the pedals.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptySun May 03, 2015 9:32 pm
Big thanks to sir psycho for his help and tools and driving my ass around running chores.
Gen V, N*, and 60 pounders are on and she's running great.
Here's a short time lapse vid:
https://instagram.com/p/2POS5gR6XI/
Charlie Robinson's '99 Riv - Page 21 20150510
Charlie Robinson's '99 Riv - Page 21 20150512
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptySun May 03, 2015 10:07 pm
Dangit Charlie, I'm trying to keep up with you on mods and you go and do this. So not cool (just kidding).
I wish there were some Rivi fans down here around me.....
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 21 EmptySun May 03, 2015 10:15 pm
Damn, Charlie.....that chrome charger looks awesome in there.Only thing is you need a chrome radiator cap.... hahaha.
Page 21 of 24Go to page : Previous  1 ... 12 ... 20, 21, 22, 23, 24  Next
» Burnie Gift 2nd - Charlie Leek opens with fast 100m in Tassie interclub
» Robinson beats Hargreaves boys to line in Latrobe Gift
» Charlie Haas no longer a member of the ROH roster?
» Memory Of Charlie Batch's Slain Sister Lives Through His Youth Foundation
» Callum Robinson
