 Dash / Radio install kit for 95?
3 posters
Iron12
Dash / Radio install kit for 95? Empty
PostSubject: Dash / Radio install kit for 95?   Dash / Radio install kit for 95? EmptySun Aug 26, 2012 6:20 pm
Newbie here, I'm installing a Kenwood KDC HD 552U unit in my 95 and would like to know which dash kit would work. Crutchfield of course says no units will fit and I don't trust some of the other web sights. The dash and radio are currently disassembled and I do realize I may have to dremel out where the oem radio was. I haven't been able to find any part numbers in the forum and if I over looked any obvious answers I apologize in advance.
Thanks!
PostSubject: Re: Dash / Radio install kit for 95?   Dash / Radio install kit for 95? EmptySun Aug 26, 2012 6:59 pm
they all fit. you just have to get creative with your dremel. nibble a little bit at a time.
Merit : 180
PostSubject: Re: Dash / Radio install kit for 95?   Dash / Radio install kit for 95? EmptyMon Aug 27, 2012 5:37 pm
If you were looking for a bolt-in radio you are hosed.
if you have/can modify the dash (including fabricating a bracket out of sheet steel or heavier aluminum) you will be OK.
Iron12
PostSubject: Re: Dash / Radio install kit for 95?   Dash / Radio install kit for 95? EmptyWed Aug 29, 2012 6:02 pm
For a single din radio (Kenwood series) the Scoshe GM1504 works with no cutting required. It looks good and sounds great with the premium factory speakers.
» Write-Up: BD Trims and Sherwood Dash Kit Installation
» DO YOU HAVE TO REMOVE THE DASH TO INSTALL A PCM?
» Made a purchase from intense yesterday
» Write-Up: HVAC Assembly
» GPS Unit/Install for Riv?
