 ext temp weirdness on 95 riv SC
sniperdude
sniperdude
Merit : 18
ext temp weirdness on 95 riv SC Empty
PostSubject: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Sep 11, 2012 3:36 pm
Anybody know if there's a sensor or something that can cause the ext temp to read incorrectly?
Can I replace it or know where to get one?
Thanks!
ext temp weirdness on 95 riv SC 20120606081704
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Sep 11, 2012 4:43 pm
Its actually just that hot out today!! shocked
But in all seriousness, the sensor is right in front of the radiator and condenser mounted to the bottom of the radiator support. You can see it without opening the hood just looking through the gap in the bumper below the license plate. It should be somewhere on the right side, very easy to get at!
sniperdude
sniperdude
Merit : 18
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Sep 11, 2012 5:08 pm
Awesome, will check that out thanks. Are there replacements available for it?
rk0ehn
rk0ehn
Name : Christian Rolf Köhn
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Sep 11, 2012 5:12 pm
sniperdude
sniperdude
Merit : 18
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Sep 11, 2012 5:14 pm
Wicked, thanks a bunch guys.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Oct 16, 2012 12:13 pm
Thanks again for the information about that sensor, gents. happy
I plugged in the new one, turned on the car and it said 199F. I was like DAMNIT! and then 10 seconds later corrected to the real ambient temp. I was pissed for a minute! LOL
sniperdude
sniperdude
Merit : 18
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Oct 16, 2012 12:15 pm
Does anyone have a picture of how their sensor is mounted? Because mine was hanging there and I'm not sure where it actually bolts up to.
PostSubject: Re: ext temp weirdness on 95 riv SC   ext temp weirdness on 95 riv SC EmptyTue Oct 16, 2012 12:44 pm
It can break on its mount (most do, imo) Mines just sitting in the lower moulding (taped in), and still works fine. If you look around, near the bottom of the radiator you'll see where it fastens on. One screw holds it on. I wouldn't worry about it not working. Again, mine's fine taped to inside of moulding.
» Water Temp Gauge
» Temp light on when engine is cold??
» Players In-Out/Temp Loan Spells
» Temp light keeps coming on
» Atmospheric pressure & Pike
