 wiring question...
duster_do_little
duster_do_little
wiring question... Empty
PostSubject: wiring question...   wiring question... EmptyTue Oct 16, 2012 6:16 pm
I installed a couple of strip lights in the door sill, right under the word Riviera . I was wondering the best way to wire them up so that they turn on when the door is open. I was just going to wire them into the door light, but that invloves running a lot of wire for the lights. Is there an easy place that I can wire into. I looked at the fuse box and after removing the fuse and noticing that all of my lights still worked I figured I would ask on here
Merit : 154
PostSubject: Re: wiring question...   wiring question... EmptyTue Oct 16, 2012 11:17 pm
you kind of have to wire them into the door light, because the lights are actually controlled by a lighting "module" (read - a small computer).
duster_do_little
duster_do_little
PostSubject: Re: wiring question...   wiring question... EmptyTue Oct 16, 2012 11:46 pm
where is said module?
Merit : 154
PostSubject: Re: wiring question...   wiring question... EmptyWed Oct 17, 2012 12:11 am
IIRC next to the fuse block. But I don't remember actually and can't get to my manuals ATM. Someone else will chime in, no doubt.
duster_do_little
duster_do_little
PostSubject: Re: wiring question...   wiring question... EmptyWed Oct 17, 2012 2:18 am
okay, thanks...might just be easier to wire into the door if it's by the fuse block
wiring question...
» Kohler CV13 wiring question
» Pulley Question
» grip strength advice..ask david horne any question on grip training....
» J Strong Top wiring/Rhino
» Level Adjust Question
