 Bose Catera Radio
Bose Catera Radio Empty
PostSubject: Bose Catera Radio   Bose Catera Radio EmptySun Nov 11, 2012 3:18 am
Was wondering if this Bose radio will work in the Riviera. UL6? Couldn't find if the wiring harness was the same.
http://buffalo.craigslist.org/pts/3401434455.html
PostSubject: Re: Bose Catera Radio   Bose Catera Radio EmptySun Nov 11, 2012 10:06 am
It's not going to just plug & play, but for only $20 it could be worth trying. Might work. From pics it appears the bezel is curved on left & right edges, not straight. So you would need to modify it somehow to look good in the Riv's dash. I also read this system may need to be programmed by the dealer, which costs $45.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/9373224/vpcsid/0/SFV/30046
PostSubject: Re: Bose Catera Radio   Bose Catera Radio EmptyMon Nov 12, 2012 10:43 am
The radio itself only puts out a pre-amp signal. There are two separate amps required for this! Don't think it's worth the overhaul!
Merit : 155
PostSubject: Re: Bose Catera Radio   Bose Catera Radio EmptyMon Nov 12, 2012 8:14 pm
Yeah it could be a bit much. However with some luck a junker with the needed amps is in your neighborhood pick-n-pull.
Bose Catera Radio
» Micron Radio Control
» Radio Reporter Needed
» Rhino Radio?
» Moose overhead radio unit
» Pike - Living World Radio 4
