 secret compartment
pwriv97
PostSubject: secret compartment   Sun Nov 18, 2012 7:04 pm
in the center console right behind the shifter, down in that compartment there is a little trap door. it has a little handle on it but it wont open. anyone know what this is??
PostSubject: Re: secret compartment   Sun Nov 18, 2012 7:22 pm
ive allways wondered the same thing. went so far as to pop it open,still didnt figure it out.did you pop it open?
Merit : 62
PostSubject: Re: secret compartment   Sun Nov 18, 2012 7:26 pm
Sorry to be a downer, but it's simply a cover for two bolts that hold the center console to the floor lol. It's a little difficult to remove but I've never broken one removing it. Flat head screwdriver works pretty well.
PostSubject: Re: secret compartment   Sun Nov 18, 2012 7:51 pm
it could become a secret compartment.
Merit : 131
PostSubject: Re: secret compartment   Sun Nov 18, 2012 9:06 pm
...an easier compartment could be installed in the part of the center console under the dash, just above the gas pedal and to the right you can reach around and in. I had a similar space in a different car, in which I hid the transceiver for a one-hand (channel selector in mic) CB radio. Bolted it right to the floor. Was a nice, stealth installation including a combination CB AM FM antenna, which worked although actually did none of the radio frequencies that well. I ended up using a magnet-mount CB whip for highway trips.
Also if you look at it carefully there is some space under the rear seat. Watch out for heat from the exhaust and electricals. That (under rear seat) is the area where dealers would install the dealer-option Motorola cellphone transceiver.
Merit : 122
PostSubject: Re: secret compartment   Mon Nov 19, 2012 9:11 am
another secret compartment in the riv is to take your rear side ashtray, grab the door, and pull it straight up. It just pops out. Under is a *giant* empty area.
PostSubject: Re: secret compartment   Mon Nov 19, 2012 11:40 am
lol The "DOG"S", will smell that stink hole!! lol
PostSubject: Re: secret compartment   Mon Nov 19, 2012 1:05 pm
Secret compartments are for drugs, duh! smoke
secret compartment
