 INTENSE vs. ZZP SC Pulleys
Merit : 100
PostSubject: Re: INTENSE vs. ZZP SC Pulleys   Thu Jun 11, 2009 8:35 pm
I use an INTENSE hub with INTENSE pulley using inside grooves. When I mount a ZZP pulley, I use the middle grooves.
Ahhh... Then I'll bet if I were to change from the ZZP 3.6 to an INTENSE 3.5, I'd move the other way, from the outside grooves to the middle ones.
Merit : 239
PostSubject: Re: INTENSE vs. ZZP SC Pulleys   Thu Jun 11, 2009 9:32 pm
thumbsup Yep, that's my guess. As long as you are aware there may be a shift when changing pulleys from one brand to the next. And now, after you've shared your experience with the ZZP hub, we can start to understand how the hub, as well as pulley, affects the belt alignment.
^^^ RIV IS FOR SALE! ^^^
PostSubject: temp   Thu Feb 14, 2013 11:49 pm
Mark, I think the SC belt should be in the middle grooves, not the outsides. Otherwise, check the belt's alignment down on the crank pulley. See link:
http://rivperformance.editboard.com/series-ii-engine-transmission-f4/intense-vs-zzp-sc-pulleys-t971.htm
My belt is on the outside grooves of the ZZP pulley. It whined like a bitch when it was in the center grooves. Never again!
Merit : 239
PostSubject: Re: INTENSE vs. ZZP SC Pulleys   Fri Feb 15, 2013 12:08 am
You're using a ZZP hub. Use the middle grooves if you are running a ZZP pulley on an INTENSE hub.
